HP Pavilion G7-2235DX Screen Replacement
    1. HP Pavilion G7-2235DX Screen Replacement, Fan: step 1, image 1 of 1
      • Flip the laptop over and remove six 7.25mm screws.
      Ask FixBot
    2. HP Pavilion G7-2235DX Screen Replacement: step 2, image 1 of 2 HP Pavilion G7-2235DX Screen Replacement: step 2, image 2 of 2
      • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
      • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
      Ask FixBot
    3. HP Pavilion G7-2235DX Screen Replacement: step 3, image 1 of 2 HP Pavilion G7-2235DX Screen Replacement: step 3, image 2 of 2
      • Remove the four 7.25mm screws located by the red markers.
      Ask FixBot
    4. HP Pavilion G7-2235DX Screen Replacement: step 4, image 1 of 2 HP Pavilion G7-2235DX Screen Replacement: step 4, image 2 of 2
      • Gently lift the panel up, exposing the inside of the laptop.
      Ask FixBot
    5. HP Pavilion G7-2235DX Screen Replacement: step 5, image 1 of 2 HP Pavilion G7-2235DX Screen Replacement: step 5, image 2 of 2
      • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
      Ask FixBot
    1. HP Pavilion G7-2235DX Screen Replacement, Screen: step 6, image 1 of 1
      • To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
      • First, remove the two 7.25mm screws found in the upper right corner as shown.
      Ask FixBot
    2. HP Pavilion G7-2235DX Screen Replacement: step 7, image 1 of 2 HP Pavilion G7-2235DX Screen Replacement: step 7, image 2 of 2
      • Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
      Ask FixBot
    3. HP Pavilion G7-2235DX Screen Replacement: step 8, image 1 of 2 HP Pavilion G7-2235DX Screen Replacement: step 8, image 2 of 2
      • Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
      Ask FixBot
3 other people completed this guide.
Bre'Anna Sanders
166 Reputation
2 Guides authored
USF Tampa, Team 1-7, Leahy Fall 2016 Member of USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 108
All Time: 898
