HP Pavilion G7-2235DX RAM Replacement
    1. HP Pavilion G7-2235DX RAM Replacement, Battery: step 1, image 1 of 1
      • Before beginning, make sure the laptop is properly shut down and charger is detached.
      • Slide the battery release switch to the center of the computer to release the battery.
      Ask FixBot
    2. HP Pavilion G7-2235DX RAM Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. HP Pavilion G7-2235DX RAM Replacement, RAM: step 3, image 1 of 2 HP Pavilion G7-2235DX RAM Replacement, RAM: step 3, image 2 of 2
      • Loosen the 7.25mm screw on the bottom of the laptop holding the "L" shaped cover down.
      Ask FixBot
    2. HP Pavilion G7-2235DX RAM Replacement: step 4, image 1 of 2 HP Pavilion G7-2235DX RAM Replacement: step 4, image 2 of 2
      • Slide the cover towards you, then pull up to remove it.
      Ask FixBot
    3. HP Pavilion G7-2235DX RAM Replacement: step 5, image 1 of 2 HP Pavilion G7-2235DX RAM Replacement: step 5, image 2 of 2
      • Locate the RAM card and the two prongs holding it in place.
      Ask FixBot
    4. HP Pavilion G7-2235DX RAM Replacement: step 6, image 1 of 1
      • Using either your fingers or two metal tools, push outwards on the two prongs until the RAM card pops out.
      Ask FixBot
    5. HP Pavilion G7-2235DX RAM Replacement: step 7, image 1 of 1
      • The RAM card can now be pulled out at a slight angle.
      Ask FixBot
Dante Mugnaini
258 Reputation
2 Guides authored
USF Tampa, Team 1-7, Leahy Fall 2016 Member of USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 91
All Time: 843
