HP Pavilion G60-630US Power Button Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
33
Past 30 Days:
115
All Time:
2,945
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The power button may not be turning on the laptop. There may be a disconnect of wires or the power bar chip may be defective. If the power button is not working or broken and it needs to be replaced, the following steps show how to replace the components that make the power button work.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. HP Pavilion G60-630US Power Button Replacement, Battery: step 1, image 1 of 3 HP Pavilion G60-630US Power Button Replacement, Battery: step 1, image 2 of 3 HP Pavilion G60-630US Power Button Replacement, Battery: step 1, image 3 of 3
      • Make sure the laptop is powered off and unplugged first.
      • Turn your laptop over so the bottom is facing up.
      • Locate the battery latch and slide the latch switch all the way to the left.
      • The latch will lock and stay in place.
      Ask FixBot
    2. HP Pavilion G60-630US Power Button Replacement: step 2, image 1 of 3 HP Pavilion G60-630US Power Button Replacement: step 2, image 2 of 3 HP Pavilion G60-630US Power Button Replacement: step 2, image 3 of 3
      • Carefully lift the battery out and away from the laptop.
      Ask FixBot
    1. HP Pavilion G60-630US Power Button Replacement, Power Button: step 3, image 1 of 3 HP Pavilion G60-630US Power Button Replacement, Power Button: step 3, image 2 of 3 HP Pavilion G60-630US Power Button Replacement, Power Button: step 3, image 3 of 3
      • Open the laptop normally.
      • Using your fingers (or a spudger if needed), loosen the silver cover surrounding the keyboard.
      • You will not be able to fully remove the keyboard/silver border all the way until the next step.
      Ask FixBot
    2. HP Pavilion G60-630US Power Button Replacement: step 4, image 1 of 3 HP Pavilion G60-630US Power Button Replacement: step 4, image 2 of 3 HP Pavilion G60-630US Power Button Replacement: step 4, image 3 of 3
      • Carefully place your hands underneath the now loosened keyboard and locate the ribbon keeping the keyboard connected to the laptop.
      • Locate the tabs keeping the ribbon in place.
      • Gently push the tabs inward to release the ribbon and to detach the keyboard.
      • Carefully remove the keyboard and place it off to the side.
      • The silver border and the power button will still be connected by a different ribbon.
      Ask FixBot
    3. HP Pavilion G60-630US Power Button Replacement: step 5, image 1 of 3 HP Pavilion G60-630US Power Button Replacement: step 5, image 2 of 3 HP Pavilion G60-630US Power Button Replacement: step 5, image 3 of 3
      • Locate the ribbon keeping the power button attached to the laptop.
      • Push the tab attaching the ribbon to the laptop to detach the silver border and the power button.
      Ask FixBot
    4. HP Pavilion G60-630US Power Button Replacement: step 6, image 1 of 3 HP Pavilion G60-630US Power Button Replacement: step 6, image 2 of 3 HP Pavilion G60-630US Power Button Replacement: step 6, image 3 of 3
      • If you are looking at this in the HP Pavilion G60-630US Screen Replacement Guide, ignore this step
      • Flip the silver border over to expose the underside of the power bar.
      • Unscrew the 4 screws keeping the power bar in place. Place the screws off the the side.
      • Carefully remove the power bar.
      Ask FixBot
[deleted]
213 Reputation
2 Guides authored
1 Guide Comment
You have neglected to speak about removal of 5 screws from the bottom of the laptop! 3 inside the battery compartment and 2 on the corners of the laptop. Removal of these allow removal of the bezel and keyboard. Failure to remove these screws will cause damage to the keyboard and bezel!
Dave - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 115
All Time: 2,945
