HP Pavilion G60-247CL Screen Replacement
    1. HP Pavilion G60-247CL Screen Replacement, Battery: step 1, image 1 of 3 HP Pavilion G60-247CL Screen Replacement, Battery: step 1, image 2 of 3 HP Pavilion G60-247CL Screen Replacement, Battery: step 1, image 3 of 3
      • Press down and to the right on the battery lock slide.
      • Once slid over to the right the battery will pop up and out.
      Ask FixBot
    1. HP Pavilion G60-247CL Screen Replacement, Screen: step 2, image 1 of 1
      • Remove the seven Phillips #1 screws from the back side of the laptop.
      Ask FixBot
    2. HP Pavilion G60-247CL Screen Replacement: step 3, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 3, image 2 of 2
      • Remove the seven Phillips #0 screws from the battery compartment.
      Ask FixBot
    3. HP Pavilion G60-247CL Screen Replacement: step 4, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 4, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 4, image 3 of 3
      • Turn the computer around to the front side.
      • Using an opening tool, prop open the keyboard casing.
      Ask FixBot
    4. HP Pavilion G60-247CL Screen Replacement: step 5, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 5, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 5, image 3 of 3
      • Carefully lift up the keyboard.
      • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
      Ask FixBot
    5. HP Pavilion G60-247CL Screen Replacement: step 6, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 6, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 6, image 3 of 3
      • At the top right of the laptop there will be another wire clip holding the keyboard casing.
      • Carefully pull out the wire clip to fully detach the covering.
      Ask FixBot
    6. HP Pavilion G60-247CL Screen Replacement: step 7, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
      Ask FixBot
    7. HP Pavilion G60-247CL Screen Replacement: step 8, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 8, image 2 of 2
      • Remove the black wire from the top right corner by gently pulling outward.
      Ask FixBot
    8. HP Pavilion G60-247CL Screen Replacement: step 9, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 9, image 2 of 2
      • At the top left of the computer remove the black clip using the opening tool.
      • Push the opening tool to the right to pop out the clip.
      Ask FixBot
    9. HP Pavilion G60-247CL Screen Replacement: step 10, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 10, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 10, image 3 of 3
      • Locate at the bottom left of the computer a white clip.
      • Using an opening tool, prop out the white clip.
      Ask FixBot
    10. HP Pavilion G60-247CL Screen Replacement: step 11, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 11, image 2 of 2
      • On the left side of the computer locate the black wire with the clear clip.
      • Gently pull the wire to the right to detach it.
      Ask FixBot
    11. HP Pavilion G60-247CL Screen Replacement: step 12, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 12, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 12, image 3 of 3
      • At the top corners of the computer, unscrew the three Phillips #0 screws.
      • Lift up the top half of the computer carefully.
      Ask FixBot
    12. HP Pavilion G60-247CL Screen Replacement: step 13, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 13, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 13, image 3 of 3
      • Locate the two screws at the bottom corners of the screen.
      • Using the tweezers remove the rubber black covering over the screw.
      • Remove the two Phillips #0 screws.
      Ask FixBot
    13. HP Pavilion G60-247CL Screen Replacement: step 14, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 14, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 14, image 3 of 3
      • Using the opening tool, prop off the screen covering.
      • Remove the covering to expose the screen completely.
      Ask FixBot
    14. HP Pavilion G60-247CL Screen Replacement: step 15, image 1 of 3 HP Pavilion G60-247CL Screen Replacement: step 15, image 2 of 3 HP Pavilion G60-247CL Screen Replacement: step 15, image 3 of 3
      • Remove the bottom two screen bearings.
      • Using a Phillips 1 screwdriver, remove the two screws on each side.
      Ask FixBot
    15. HP Pavilion G60-247CL Screen Replacement: step 16, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 16, image 2 of 2
      • Using the tweezers remove the red and white wire from the bottom of the screen.
      Ask FixBot
    16. HP Pavilion G60-247CL Screen Replacement: step 17, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 17, image 2 of 2
      • Prop the screen up slightly.
      • Using the tweezers unclip the white wire.
      Ask FixBot
    17. HP Pavilion G60-247CL Screen Replacement: step 18, image 1 of 2 HP Pavilion G60-247CL Screen Replacement: step 18, image 2 of 2
      • While the screen is still propped open, remove the black wire from the bottom middle of the screen by pulling gently.
      Ask FixBot
    18. HP Pavilion G60-247CL Screen Replacement: step 19, image 1 of 1
      • Remove the screen from the outer casing carefully.
      Ask FixBot
Haley Matthews
517 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 67
All Time: 728
