Up to 20% off select tools
HP Pavilion G60-247CL RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
49
All Time:
606
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. HP Pavilion G60-247CL RAM Replacement, Battery: step 1, image 1 of 3 HP Pavilion G60-247CL RAM Replacement, Battery: step 1, image 2 of 3 HP Pavilion G60-247CL RAM Replacement, Battery: step 1, image 3 of 3
      • Press down and to the right on the battery lock slide.
      • Once slid over to the right the battery will pop up and out.
      Ask FixBot
    1. HP Pavilion G60-247CL RAM Replacement, RAM: step 2, image 1 of 1
      • Locate RAM access door on the bottom side of the laptop.
      Ask FixBot
    2. HP Pavilion G60-247CL RAM Replacement: step 3, image 1 of 3 HP Pavilion G60-247CL RAM Replacement: step 3, image 2 of 3 HP Pavilion G60-247CL RAM Replacement: step 3, image 3 of 3
      • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
      Ask FixBot
    3. HP Pavilion G60-247CL RAM Replacement: step 4, image 1 of 2 HP Pavilion G60-247CL RAM Replacement: step 4, image 2 of 2
      • Lift up on the RAM cover and remove it to reveal RAM sticks.
      Ask FixBot
    4. HP Pavilion G60-247CL RAM Replacement: step 5, image 1 of 2 HP Pavilion G60-247CL RAM Replacement: step 5, image 2 of 2
      • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
      Ask FixBot
    5. HP Pavilion G60-247CL RAM Replacement: step 6, image 1 of 1
      • Gently lift the RAM stick up and out of its seat.
      Ask FixBot
    6. HP Pavilion G60-247CL RAM Replacement: step 7, image 1 of 1
      • Repeat the previous two steps for the remaining stick of RAM.
      Ask FixBot
Author
with
Zachary Herrera
485 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 49
All Time: 606
