HP Pavilion G60-235DX Keyboard Replacement
    1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: step 1, image 1 of 2 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: step 1, image 2 of 2
      • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
      • Slide the lock to remove the battery
      • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
      Ask FixBot
    2. HP Pavilion G60-235DX Keyboard  Replacement: step 2, image 1 of 3 HP Pavilion G60-235DX Keyboard  Replacement: step 2, image 2 of 3 HP Pavilion G60-235DX Keyboard  Replacement: step 2, image 3 of 3
      • Do not force if the frame is not coming out. It may break the clip of the frame.
      • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
      • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
      • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
      • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
      Ask FixBot
    3. HP Pavilion G60-235DX Keyboard  Replacement: step 3, image 1 of 1
      • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
      • The keyboard is now detached from the computer.
      Ask FixBot
Gilbert Han
265 Reputation
2 Guides authored
Cal Poly, Team 10-5, Banghart Winter 2017 Member of Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 106
All Time: 912
