HP Pavilion G6-2249wm screen Replacement
    1. HP Pavilion G6-2249wm screen Replacement, Battery removal: step 1, image 1 of 1
      • Make sure the computer is shut off.
      • When you know that is shut off you may remove the battery
      Ask FixBot
    2. HP Pavilion G6-2249wm screen Replacement, Begin screen removal: step 2, image 1 of 1
      • Remove the little pieces of black sticky tape covering the screws that need to be removed in each lower corner
      Ask FixBot
    3. HP Pavilion G6-2249wm screen Replacement, screw removal: step 3, image 1 of 1
      • After the little black sticky tape is removed the two little screws at the lower corners of the screen need to be removed (place the screws on a little piece of tape).
      Ask FixBot
    4. HP Pavilion G6-2249wm screen Replacement, screen cover removal: step 4, image 1 of 2 HP Pavilion G6-2249wm screen Replacement, screen cover removal: step 4, image 2 of 2
      • After removing the screws, pop out the plastic protector (can be done with your fingers).
      • Start at one corner and run your finger under the plastic and it will pop out.
      Ask FixBot
    5. HP Pavilion G6-2249wm screen Replacement, screen screw removal: step 5, image 1 of 1
      • On each side of the screen there are two little screws, one on top and one on bottom.
      • All four of the screws need to be removed (place the screws on a little piece of tape so they won't be lost).
      Ask FixBot
    6. HP Pavilion G6-2249wm screen Replacement, screen removal: step 6, image 1 of 1
      • Once the screws are out, remove the screen and lay it on your keyboard.
      Ask FixBot
    7. HP Pavilion G6-2249wm screen Replacement, digital attachment removal: step 7, image 1 of 3 HP Pavilion G6-2249wm screen Replacement, digital attachment removal: step 7, image 2 of 3 HP Pavilion G6-2249wm screen Replacement, digital attachment removal: step 7, image 3 of 3
      • Once the screen is laying down you will see a connector on the back of it.
      • Pull the sticker off which pulls the connector with it.
      Ask FixBot
    8. HP Pavilion G6-2249wm screen Replacement, Reconnecting the screen: step 8, image 1 of 1
      • After the new screen has arrived, reconnect the little connecter strip.
      Ask FixBot
    9. HP Pavilion G6-2249wm screen Replacement, Replacing the screws: step 9, image 1 of 2 HP Pavilion G6-2249wm screen Replacement, Replacing the screws: step 9, image 2 of 2
      • After the connecter has been connected place the screen back into its place.
      • Once the screen is in place put in the four little screws that go in each corner of the screen.
      Ask FixBot
    10. HP Pavilion G6-2249wm screen Replacement, black cover placement: step 10, image 1 of 2 HP Pavilion G6-2249wm screen Replacement, black cover placement: step 10, image 2 of 2
      • After the screen is screwed in place the black plastic cover back over the screen.
      • Once the black over is in place start clicking the clips back into place by just pressing with your fingers.
      Ask FixBot
    11. HP Pavilion G6-2249wm screen Replacement, Screwing the cover in place: step 11, image 1 of 1
      • After the black cover is in place start to but the two little screws back in the two button corners
      Ask FixBot
    12. HP Pavilion G6-2249wm screen Replacement, Sticker placement: step 12, image 1 of 1
      • After the screws are in place the little black sticker over the screws.
      Ask FixBot
    13. HP Pavilion G6-2249wm screen Replacement, Placing the battery: step 13, image 1 of 1
      • After the screen is in and everything is tight and in place you may but the battery back in.
      Ask FixBot
    14. HP Pavilion G6-2249wm screen Replacement, Turning on the computer: step 14, image 1 of 1
      • Once the battery is in place you may turn is it on and watch your screen come back to life.
      Ask FixBot
10 other people completed this guide.
hunter
321 Reputation
1 Guide authored
Vegas Room H9 Member of Vegas Room H9
Community
13 Members
120 Guides authored
1 Guide Comment
Good guide. Easiest screen replacement ever.
I’m concerned about your poor little knuckles.
Jim Buchholz - Reply Share
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 31
All Time: 4,651
