HP Pavilion G6-1d16dx Screen hinges Replacement
    1. HP Pavilion G6-1d16dx Screen hinges Replacement, Battery: step 1, image 1 of 1
      • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
      Ask FixBot
    2. HP Pavilion G6-1d16dx Screen hinges Replacement: step 2, image 1 of 1
      • Slide the switch under the battery compartment to release the battery.
      Ask FixBot
    3. HP Pavilion G6-1d16dx Screen hinges Replacement: step 3, image 1 of 1
      • Remove the battery.
      • The battery will have popped out of the compartment when it was released.
      Ask FixBot
    1. HP Pavilion G6-1d16dx Screen hinges Replacement, Motherboard: step 4, image 1 of 1
      • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
      • The screws do not remove from the cover.
      Ask FixBot
    2. HP Pavilion G6-1d16dx Screen hinges Replacement: step 5, image 1 of 2 HP Pavilion G6-1d16dx Screen hinges Replacement: step 5, image 2 of 2
      • Unsnap the Cover by lifting the edge along the battery compartment.
      • Remove all of the body screws.
      • Remove the rubber cap and the screw underneath it.
      Ask FixBot
    3. HP Pavilion G6-1d16dx Screen hinges Replacement: step 6, image 1 of 3 HP Pavilion G6-1d16dx Screen hinges Replacement: step 6, image 2 of 3 HP Pavilion G6-1d16dx Screen hinges Replacement: step 6, image 3 of 3
      • The keyboard is held in by nine tabs
      • Using a metal tool, depress the center tab and pry up the keyboard by pivoting the tool towards the screen.
      Ask FixBot
    4. HP Pavilion G6-1d16dx Screen hinges Replacement: step 7, image 1 of 2 HP Pavilion G6-1d16dx Screen hinges Replacement: step 7, image 2 of 2
      • Slide the tool that is now under the keyboard sideways along the edge and use another tool to depress the other tabs along the edge of the keyboard.
      • As you depress the tabs, the edges of the keyboard will pop up.
      • Lift off the keyboard
      Ask FixBot
    5. HP Pavilion G6-1d16dx Screen hinges Replacement: step 8, image 1 of 1
      • Flip up the black tab holding the keyboard in place via the ribbon cable and pull out the cable
      Ask FixBot
    6. HP Pavilion G6-1d16dx Screen hinges Replacement: step 9, image 1 of 3 HP Pavilion G6-1d16dx Screen hinges Replacement: step 9, image 2 of 3 HP Pavilion G6-1d16dx Screen hinges Replacement: step 9, image 3 of 3
      • Remove the two remaining ribbon cables.
      • Remove the screws holding in the protective cover underneath the keyboard.
      • Pop the cover off using any flat metal tool, starting with where you took out the optical drive
      • It will be very sticky near the edge closest to the screen. This is where the sticker in the battery compartment is stuck to. just use a little more force.
      Ask FixBot
    7. HP Pavilion G6-1d16dx Screen hinges Replacement: step 10, image 1 of 1
      • Unplug the ribbon cable on the right side of the motherboard.
      Ask FixBot
    8. HP Pavilion G6-1d16dx Screen hinges Replacement: step 11, image 1 of 2 HP Pavilion G6-1d16dx Screen hinges Replacement: step 11, image 2 of 2
      • Underneath the computer, unscrew the hard drive connector screw, and pop out the hard drive plug-in.
      Ask FixBot
    9. HP Pavilion G6-1d16dx Screen hinges Replacement: step 12, image 1 of 1
      • Unscrew all mother board screws and lift the motherboard out of the body.
      • For replacing the screen hinges and screen, skip this step
      Ask FixBot
    1. HP Pavilion G6-1d16dx Screen hinges Replacement, Screen hinges: step 13, image 1 of 1
      • Remove the five screws holding hinges to base.
      • Do not unscrew the motherboard screws
      Ask FixBot
    2. HP Pavilion G6-1d16dx Screen hinges Replacement: step 14, image 1 of 2 HP Pavilion G6-1d16dx Screen hinges Replacement: step 14, image 2 of 2
      • Lift the tape tab up from the screen plug, and unplug the screen from the motherboard.
      • Unplug the wires from the wireless card and pull them through the body.
      Ask FixBot
    3. HP Pavilion G6-1d16dx Screen hinges Replacement: step 15, image 1 of 1
      • Remove the sticky tabs on the bottom of the screen just outside the hinges, and remove the two screws underneath.
      Ask FixBot
    4. HP Pavilion G6-1d16dx Screen hinges Replacement: step 16, image 1 of 1
      • Pry off the plastic surrounding the screen with any flat metal tool.
      Ask FixBot
    5. HP Pavilion G6-1d16dx Screen hinges Replacement: step 17, image 1 of 1
      • Remove the screws holding the hinge covers in place.
      • Remove the hinge covers.
      Ask FixBot
    6. HP Pavilion G6-1d16dx Screen hinges Replacement: step 18, image 1 of 1
      • Use a pair of pliers to unscrew the nut and pull out the hinge.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Not so good a manual. See my remarks.
This laptop is of extremely poor building quality. Disaster lures in every badly made detail.
Eveline Bernard - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 46
All Time: 4,103
