HP Pavilion G6-1d16dx RAM Replacement
    1. HP Pavilion G6-1d16dx RAM Replacement, Battery: step 1, image 1 of 1
      • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
      Ask FixBot
    2. HP Pavilion G6-1d16dx RAM Replacement: step 2, image 1 of 1
      • Slide the switch under the battery compartment to release the battery.
      Ask FixBot
    3. HP Pavilion G6-1d16dx RAM Replacement: step 3, image 1 of 1
      • Remove the battery.
      • The battery will have popped out of the compartment when it was released.
      Ask FixBot
    1. HP Pavilion G6-1d16dx RAM Replacement, RAM: step 4, image 1 of 2 HP Pavilion G6-1d16dx RAM Replacement, RAM: step 4, image 2 of 2
      • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
      • The screws do not remove from the cover.
      • Unsnap the cover by lifting the edge along the battery compartment.
      Ask FixBot
    2. HP Pavilion G6-1d16dx RAM Replacement: step 5, image 1 of 1
      • Push the two tabs on the sides of the RAM compartment away from the memory stick.
      • This can be done with your fingers, or any sort of flat edged tool.
      Ask FixBot
    3. HP Pavilion G6-1d16dx RAM Replacement: step 6, image 1 of 2 HP Pavilion G6-1d16dx RAM Replacement: step 6, image 2 of 2
      • After the tabs are moved, the RAM stick will pop up, and you can pull the card straight out of its slot.
      • Place the stick (new or original) back into the same slot where you pulled the previous stick from, and press straight down on the card until the tabs click into place.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 79
All Time: 2,846
