Up to 20% off select tools
HP Pavilion G6 Screen Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
126
All Time:
2,570
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. HP Pavilion G6  Screen Replacement, Remove the battery: step 1, image 1 of 3 HP Pavilion G6  Screen Replacement, Remove the battery: step 1, image 2 of 3 HP Pavilion G6  Screen Replacement, Remove the battery: step 1, image 3 of 3
      • Close the laptop and flip it over.
      • Slide the release pin to pop the battery.
      • Remove the battery completely.
      Ask FixBot
    2. HP Pavilion G6  Screen Replacement, Remove the screw covers: step 2, image 1 of 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: step 2, image 2 of 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Open the laptop and locate the screw covers.
      • Remove the screw covers at the bottom of the screen with tweezers.
      • Keep them somewhere safe as you will need to stick them back after the repair.
      Ask FixBot
    3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: step 3, image 1 of 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: step 3, image 2 of 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: step 3, image 3 of 3
      • Unscrew the exposed 2 x Philips screws and set them aside.
      • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
      • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
      • Finally, remove the frame.
      Ask FixBot
    4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: step 4, image 1 of 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: step 4, image 2 of 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: step 4, image 3 of 3
      • Remove the black Philips screw from the top on each side.
      • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
      • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
      Ask FixBot
    5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: step 5, image 1 of 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: step 5, image 2 of 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: step 5, image 3 of 3
      • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
      • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
      • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
      Ask FixBot
    6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: step 6, image 1 of 2 HP Pavilion G6  Screen Replacement, Check the model number before ordering: step 6, image 2 of 2
      • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
      • Check the cable connector to make sure you order the correct screen with the correct number of pins.
      Ask FixBot
2 other people completed this guide.
Author
with
honakrisi
4,651 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 126
All Time: 2,570
