HP Pavilion DV9700 Optical Drive Replacement
    1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: step 1, image 1 of 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: step 1, image 2 of 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: step 1, image 3 of 3
      • Turn the device over so that the bottom is facing upward.
      • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
      • Remove this 6mm screw with a Philips #0 screwdriver.
      • This screw is very small, make sure to have an organized place to put it.
      Ask FixBot
    2. HP Pavilion DV9700 Optical Drive  Replacement: step 2, image 1 of 3 HP Pavilion DV9700 Optical Drive  Replacement: step 2, image 2 of 3 HP Pavilion DV9700 Optical Drive  Replacement: step 2, image 3 of 3
      • The optical drive is located toward the left side of the device.
      • Using a spudger, pry the optical drive away from the casing.
      • Pull the rest of the optical drive out with your hand.
      Ask FixBot
Max Shangraw
507 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 72
All Time: 755
