HP Pavilion DV3 Hard Drive Replacement
    1. HP Pavilion DV3 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
      • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
      Ask FixBot
    2. HP Pavilion DV3 Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion DV3 Hard Drive Replacement: step 2, image 2 of 2
      • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
      Ask FixBot
    1. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
      • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
      • The screw will remain attached to the cover.
      Ask FixBot
    2. HP Pavilion DV3 Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion DV3 Hard Drive Replacement: step 4, image 2 of 2
      • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
      • Put the cover and screw to the.
      • This will reveal the hard drive.
      Ask FixBot
    3. HP Pavilion DV3 Hard Drive Replacement: step 5, image 1 of 3 HP Pavilion DV3 Hard Drive Replacement: step 5, image 2 of 3 HP Pavilion DV3 Hard Drive Replacement: step 5, image 3 of 3
      • With your fingers, grab the clear tab.
      • Pull right first, and then upwards (towards you).
      • The hard drive should slide out of place and detach from the laptop.
      Ask FixBot
5 other people completed this guide.
Luke Whitmarsh
649 Reputation
2 Guides authored
Cal Poly, Team 14-10, Forte Fall 2013 Member of Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 120
All Time: 5,617
