HP Pavilion DV2160BR Keyboard Replacement
    1. HP Pavilion DV2160BR Keyboard Replacement, Battery: step 1, image 1 of 1
      • Start with the bottom of the laptop facing up.
      Ask FixBot
    2. HP Pavilion DV2160BR Keyboard Replacement: step 2, image 1 of 2 HP Pavilion DV2160BR Keyboard Replacement: step 2, image 2 of 2
      • Locate the battery compartment at the rear of the device.
      • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
      Ask FixBot
    1. HP Pavilion DV2160BR Keyboard Replacement, Keyboard: step 3, image 1 of 3 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: step 3, image 2 of 3 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Unscrew the 5 screws along the top edge of the laptop’s back panel and inside the battery compartment.
      • The two screws inside the battery compartment are 5 mm Phillips #1.
      • The three screws outside the battery compartment are 9 mm Phillips #1.
      Ask FixBot
    2. HP Pavilion DV2160BR Keyboard Replacement: step 4, image 1 of 3 HP Pavilion DV2160BR Keyboard Replacement: step 4, image 2 of 3 HP Pavilion DV2160BR Keyboard Replacement: step 4, image 3 of 3
      • Remove the three 6 mm Phillips #1 screws that are marked by a keyboard symbol. These screws are holding in the keyboard itself.
      Ask FixBot
    3. HP Pavilion DV2160BR Keyboard Replacement: step 5, image 1 of 1
      • Flip the laptop over and open the lid.
      Ask FixBot
    4. HP Pavilion DV2160BR Keyboard Replacement: step 6, image 1 of 1
      • Using a blue plastic opening tool, remove the bezel by sliding the tool along the edges.
      • The bezel is held in place by plastic tabs, which you will hear snapping out of place as you slide the plastic opener tool.
      • You don't need to take the bezel all the way off the device, and shouldn't since it it connected to the laptop by two cables.
      Ask FixBot
    5. HP Pavilion DV2160BR Keyboard Replacement: step 7, image 1 of 1
      • Lift the keyboard from the device, starting from the top sides and pulling it away from the bottom end gently.
      • The keyboard is still connected by a cable, so do not pull it too quickly as it could become damaged.
      Ask FixBot
    6. HP Pavilion DV2160BR Keyboard Replacement: step 8, image 1 of 1
      • Remove the old keyboard by gently unplugging the ribbon cable
      • Prepare the new keyboard and connect it to the laptop via the ribbon cable
      • After reconnecting the ribbon cable, ensure it is securely fastened and the connector is properly locked.
      • Carefully reassemble the keyboard into its housing, making sure all tabs are aligned. Reattach the back panel and screws, then power on the laptop to test the new keyboard.
      • Confirm that all keys are functioning correctly and the keyboard is securely in place.
      Ask FixBot
Shannon
55 Reputation
6 Guides authored
Cal Poly, Team 13-66, Johann Spring 2013 Member of Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 102
All Time: 1,343
