HP Pavilion DV2160BR Inverter Replacement
    1. HP Pavilion DV2160BR Inverter Replacement, Inverter: step 1, image 1 of 1
      • Start with the laptop sitting up and open.
      Ask FixBot
    2. HP Pavilion DV2160BR Inverter Replacement: step 2, image 1 of 3 HP Pavilion DV2160BR Inverter Replacement: step 2, image 2 of 3 HP Pavilion DV2160BR Inverter Replacement: step 2, image 3 of 3
      • Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
      • Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
      • There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
      • There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
      Ask FixBot
    3. HP Pavilion DV2160BR Inverter Replacement: step 3, image 1 of 2 HP Pavilion DV2160BR Inverter Replacement: step 3, image 2 of 2
      • Slide a plastic opener tool along the outside edges of the front screen panel, separating it from the screen. You may need to apply some firm pressure.
      • Once the panel is separated from the screen, gently pull it off and set it aside.
      Ask FixBot
    4. HP Pavilion DV2160BR Inverter Replacement: step 4, image 1 of 2 HP Pavilion DV2160BR Inverter Replacement: step 4, image 2 of 2
      • The inverter is located underneath the screen.
      • Unscrew the two 5mm Phillips #0 screws holding it in place, one on each end of the inverter.
      Ask FixBot
    5. HP Pavilion DV2160BR Inverter Replacement: step 5, image 1 of 2 HP Pavilion DV2160BR Inverter Replacement: step 5, image 2 of 2
      • Disconnect the grey LCD cable on the left side of the inverter by holding the inverter in place and pulling firmly on the connector.
      • Disconnect the backlight plug cable on the right side of the inverter by holding the inverter in place and pulling firmly on the connector.
      Ask FixBot
    6. HP Pavilion DV2160BR Inverter Replacement: step 6, image 1 of 1
      • Remove the inverter from the device.
      Ask FixBot
3 other people completed this guide.
Shannon
55 Reputation
6 Guides authored
Cal Poly, Team 13-66, Johann Spring 2013 Member of Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Members
68 Guides authored
1 Guide Comment
Thank you for enriching my knowledge.
Hope to meet you again.
ashique mahamud - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 1,882
