HP Pavilion DV1000 Screen Replacement
    1. HP Pavilion DV1000 Screen Replacement, Battery: step 1, image 1 of 1
      • Shut down the computer.
      • Disconnect all external devices and cables from the computer.
      Ask FixBot
    2. HP Pavilion DV1000 Screen Replacement: step 2, image 1 of 1
      • Flip the laptop over.
      Ask FixBot
    3. HP Pavilion DV1000 Screen Replacement: step 3, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 3, image 2 of 2
      • Locate the gray sliding tab next to the black bar where the battery is located.
      • Slide the gray sliding tab to the left until you hear a distinct click.
      • The inside edge of the battery should pop up.
      Ask FixBot
    4. HP Pavilion DV1000 Screen Replacement: step 4, image 1 of 3 HP Pavilion DV1000 Screen Replacement: step 4, image 2 of 3 HP Pavilion DV1000 Screen Replacement: step 4, image 3 of 3
      • Grasp the inside edge of the battery.
      • Lift the inside edge of the battery up to detach the battery from the laptop.
      Ask FixBot
    1. HP Pavilion DV1000 Screen Replacement, Keyboard: step 5, image 1 of 1
      • Remove the highlighted screws.
      • After removing the screws, flip the laptop over.
      Ask FixBot
    2. HP Pavilion DV1000 Screen Replacement: step 6, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 6, image 2 of 2
      • Open the laptop.
      • Use the spudger to lift the keyboard.
      • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
      • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
      Ask FixBot
    1. HP Pavilion DV1000 Screen Replacement, Media Keys: step 7, image 1 of 1
      • Turn the laptop upside-down again.
      Ask FixBot
    2. HP Pavilion DV1000 Screen Replacement: step 8, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 8, image 2 of 2
      • Turn the laptop right-side up. Open the screen and tilt it all the way back.
      • Locate the media keys.
      • Gently lift up the media key strip using the plastic pry tool.
      • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
      Ask FixBot
    1. HP Pavilion DV1000 Screen Replacement, Screen: step 9, image 1 of 1
      • Remove the rubber inserts with the spudger.
      • Note: When reassembling, notice that the two lower rubber pieces are flatter than the four rubber pieces located at the top of the screen.
      • Remove the screws behind the rubber inserts.
      Ask FixBot
    2. HP Pavilion DV1000 Screen Replacement: step 10, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 10, image 2 of 2
      • Carefully pry loose the screen casing with a plastic prying tool.
      Ask FixBot
    3. HP Pavilion DV1000 Screen Replacement: step 11, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 11, image 2 of 2
      • Remove the plug by prying it loose with the spudger.
      • Pulling the plug with your fingers could be potentially dangerous unless you are wearing work gloves.
      Ask FixBot
    4. HP Pavilion DV1000 Screen Replacement: step 12, image 1 of 1
      • Remove the single screw marked in the image.
      • Be careful not to break the clips or pull any wires.
      Ask FixBot
    5. HP Pavilion DV1000 Screen Replacement: step 13, image 1 of 3 HP Pavilion DV1000 Screen Replacement: step 13, image 2 of 3 HP Pavilion DV1000 Screen Replacement: step 13, image 3 of 3
      • Remove the 4 screws marked in the picture.
      • Support the back cover and set it down on the desk. Do not pull off the back cover.
      Ask FixBot
    6. HP Pavilion DV1000 Screen Replacement: step 14, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 14, image 2 of 2
      • Remove the screws on each side of the screen. There are four screws on each side.
      • Remove the screen.
      Ask FixBot
4 other people completed this guide.
Tyler Latour
275 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 123
All Time: 4,182
