HP Pavilion 500-259 Hard Drive Replacement
  1. HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Power down and unplug all wires from the computer before proceeding.
    • Use a Phillips #1 screwdriver to remove the single 6 mm screw securing the side panel.
    • These screws can often be removed by hand.
    Ask FixBot
  2. HP Pavilion 500-259 Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion 500-259 Hard Drive Replacement: step 2, image 2 of 2
    • Slide the front panel back and off the chassis.
    Ask FixBot
  3. HP Pavilion 500-259 Hard Drive Replacement: step 3, image 1 of 3 HP Pavilion 500-259 Hard Drive Replacement: step 3, image 2 of 3 HP Pavilion 500-259 Hard Drive Replacement: step 3, image 3 of 3
    • The hard drive is found on the left-hand side of the case.
    Ask FixBot
  4. HP Pavilion 500-259 Hard Drive Replacement: step 4, image 1 of 3 HP Pavilion 500-259 Hard Drive Replacement: step 4, image 2 of 3 HP Pavilion 500-259 Hard Drive Replacement: step 4, image 3 of 3
    • Unplug the two cables attached to the back of the hard drive.
    Ask FixBot
  5. HP Pavilion 500-259 Hard Drive Replacement: step 5, image 1 of 1
    • Place one hand underneath the hard drive to prevent it from falling, then remove the two 2 mm screws attaching the hard drive to the case with a Phillips #2 screwdriver.
    Ask FixBot
  6. HP Pavilion 500-259 Hard Drive Replacement: step 6, image 1 of 3 HP Pavilion 500-259 Hard Drive Replacement: step 6, image 2 of 3 HP Pavilion 500-259 Hard Drive Replacement: step 6, image 3 of 3
    • Slide the hard drive out of the case.
    Ask FixBot
12 other people completed this guide.
Farhan Khan
403 Reputation
1 Guide authored
2 Guide Comments
Why does it look like that drive is mounted sideways with just two screws? The original 3.5" hard drive is mounted flat to the lower 3.5 in mounting Bay. I was looking for advice on how to mount the SSD to the upper 2.5 in mounting Bay. I have serious doubts about the instructions you've posted.
Dave Hill - Reply Share
Hello Dave, this particular HP Pavilion desktop had the hard-drive mounted sideways with two screws, the 2.5" hard-drive being as lightweight as it was able to be supported by just the two screws. I made this guide about a year ago and cannot remember if the hard-drive was able to be mounted flat with the given hole placements. However, I have linked a Youtube video down below that might provide some assistance when trying to mount your 2.5" hard drive despite the video showing a 3.5" drive.
HP Hard drive replacement video: https://www.youtube.com/watch?v=PxT_qPzl...
Thank you for taking the time to look at my guide and I hope this response provides at least a little assistance.
Farhan Khan - Reply Share
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 125
All Time: 5,734
