HP Pavilion 17-x047na Back Panel Replacement
    1. HP Pavilion 17-x047na Back Panel Replacement, Battery: step 1, image 1 of 2 HP Pavilion 17-x047na Back Panel Replacement, Battery: step 1, image 2 of 2
      • Turn off and unplug the laptop before replacing the battery.
      • The netbook needs to be top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      Ask FixBot
    2. HP Pavilion 17-x047na Back Panel Replacement: step 2, image 1 of 1
      • Slide the battery out from the laptop.
      Ask FixBot
    1. HP Pavilion 17-x047na Back Panel Replacement, Back Panel: step 3, image 1 of 2 HP Pavilion 17-x047na Back Panel Replacement, Back Panel: step 3, image 2 of 2
      • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
      • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
      • Use an ejection pin to eject and remove the CD/DVD drive.
      Ask FixBot
    2. HP Pavilion 17-x047na Back Panel Replacement: step 4, image 1 of 2 HP Pavilion 17-x047na Back Panel Replacement: step 4, image 2 of 2
      • Use an iFixit opening tool to separate the back cover from the laptop.
      • Gently pry open the cover, trying not to break the plastic.
      Ask FixBot
Sarah Westberg
43,283 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,882 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 60
All Time: 1,015
