HP Pavilion 17-g119dx RAM Replacement
    1. HP Pavilion 17-g119dx RAM Replacement, Battery: step 1, image 1 of 1
      • Close your laptop and turn it over so that the bottom is facing up.
      Ask FixBot
    2. HP Pavilion 17-g119dx RAM Replacement: step 2, image 1 of 2 HP Pavilion 17-g119dx RAM Replacement: step 2, image 2 of 2
      • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
      Ask FixBot
    3. HP Pavilion 17-g119dx RAM Replacement: step 3, image 1 of 2 HP Pavilion 17-g119dx RAM Replacement: step 3, image 2 of 2
      • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
      Ask FixBot
    4. HP Pavilion 17-g119dx RAM Replacement: step 4, image 1 of 2 HP Pavilion 17-g119dx RAM Replacement: step 4, image 2 of 2
      • Grab the battery and remove it from the laptop.
      Ask FixBot
    1. HP Pavilion 17-g119dx RAM Replacement, RAM: step 5, image 1 of 3 HP Pavilion 17-g119dx RAM Replacement, RAM: step 5, image 2 of 3 HP Pavilion 17-g119dx RAM Replacement, RAM: step 5, image 3 of 3
      • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
      • Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
      Ask FixBot
    2. HP Pavilion 17-g119dx RAM Replacement: step 6, image 1 of 3 HP Pavilion 17-g119dx RAM Replacement: step 6, image 2 of 3 HP Pavilion 17-g119dx RAM Replacement: step 6, image 3 of 3
      • Remove the black corner covers on either side of the battery to reveal four additional 6.5mm Phillips #00 screws.
      Ask FixBot
    3. HP Pavilion 17-g119dx RAM Replacement: step 7, image 1 of 3 HP Pavilion 17-g119dx RAM Replacement: step 7, image 2 of 3 HP Pavilion 17-g119dx RAM Replacement: step 7, image 3 of 3
      • Remove the four 6.5mm Phillips #00 screws that were underneath the black corner covers.
      Ask FixBot
    4. HP Pavilion 17-g119dx RAM Replacement: step 8, image 1 of 3 HP Pavilion 17-g119dx RAM Replacement: step 8, image 2 of 3 HP Pavilion 17-g119dx RAM Replacement: step 8, image 3 of 3
      • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
      Ask FixBot
    5. HP Pavilion 17-g119dx RAM Replacement: step 9, image 1 of 3 HP Pavilion 17-g119dx RAM Replacement: step 9, image 2 of 3 HP Pavilion 17-g119dx RAM Replacement: step 9, image 3 of 3
      Tool used on this step:
      iFixit Opening Tool
      $1.99
      Buy
      • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
      • Flip the computer back over with the screen facing up and open the laptop.
      • Use the Plastic Opening Tool to separate the face plate from the backing.
      Ask FixBot
    6. HP Pavilion 17-g119dx RAM Replacement: step 10, image 1 of 2 HP Pavilion 17-g119dx RAM Replacement: step 10, image 2 of 2
      iFixit Opening Tool
      $1.99
      Buy
      • After running the Plastic Opening Tool along the sides, you can gently lift the keyboard up and on top of the screen to access the RAM.
      • The RAM will be located above the Motherboard and next to the Processor.
      Ask FixBot
    7. HP Pavilion 17-g119dx RAM Replacement: step 11, image 1 of 2 HP Pavilion 17-g119dx RAM Replacement: step 11, image 2 of 2
      • Release the RAM by pulling the two white levers away from the sides of the RAM.
      Ask FixBot
    8. HP Pavilion 17-g119dx RAM Replacement: step 12, image 1 of 1
      • Pull the RAM up and out of the laptop to remove it.
      • When reassembling, be sure to insert the RAM at the same angle it came out. Then push it down into place.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
Ddr3 or ddr4?
Andres Toro - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 120
All Time: 3,309
