HP Pavilion 17-f004dx Screen Replacement
    1. HP Pavilion 17-f004dx Screen Replacement, Battery: step 1, image 1 of 1
      • Before you remove the battery, make sure the laptop is powered off.
      • Slide the black battery latches inward to remove the battery.
      Ask FixBot
    2. HP Pavilion 17-f004dx Screen Replacement: step 2, image 1 of 1
      • Pull the battery out towards you while your fingers are still holding the latches in place.
      Ask FixBot
    1. HP Pavilion 17-f004dx Screen Replacement, CD Drive: step 3, image 1 of 1
      • Remove one 7 mm screw with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Pavilion 17-f004dx Screen Replacement: step 4, image 1 of 3 HP Pavilion 17-f004dx Screen Replacement: step 4, image 2 of 3 HP Pavilion 17-f004dx Screen Replacement: step 4, image 3 of 3
      • Use a metal spudger to push the CD drive out of its slot for removal.
      Ask FixBot
    1. HP Pavilion 17-f004dx Screen Replacement, Front Panel: step 5, image 1 of 1
      • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Pavilion 17-f004dx Screen Replacement: step 6, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 6, image 2 of 2
      • Remove the thin plastic cover using the flat metal spudger to expose another screw.
      • Remove one 7 mm screw with a Phillips #0 screwdriver.
      Ask FixBot
    3. HP Pavilion 17-f004dx Screen Replacement: step 7, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 7, image 2 of 2
      • Use a metal spudger to remove the rubber "feet" to expose two screws.
      Ask FixBot
    4. HP Pavilion 17-f004dx Screen Replacement: step 8, image 1 of 1
      • Underneath each rubber foot, there is a screw.
      • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
      Ask FixBot
    5. HP Pavilion 17-f004dx Screen Replacement: step 9, image 1 of 1
      • Remove the two black end caps to expose more screws.
      • The end caps will require some force to remove.
      Ask FixBot
    6. HP Pavilion 17-f004dx Screen Replacement: step 10, image 1 of 1
      • Remove the following six screws with a Phillips #1 screwdriver:
      • Two 7 mm screws.
      • Two 7 mm screws.
      • Two 4.8 mm screws.
      Ask FixBot
    7. HP Pavilion 17-f004dx Screen Replacement: step 11, image 1 of 1
      • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
      Ask FixBot
    8. HP Pavilion 17-f004dx Screen Replacement: step 12, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 12, image 2 of 2
      • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
      Ask FixBot
    9. HP Pavilion 17-f004dx Screen Replacement: step 13, image 1 of 1
      • Partially lift the top cover from the enclosure.
      Ask FixBot
    10. HP Pavilion 17-f004dx Screen Replacement: step 14, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 14, image 2 of 2
      • Remove the ribbon connecting the power button to the motherboard.
      Ask FixBot
    11. HP Pavilion 17-f004dx Screen Replacement: step 15, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 15, image 2 of 2
      • Remove the ribbon connecting the mousepad to the motherboard.
      Ask FixBot
    12. HP Pavilion 17-f004dx Screen Replacement: step 16, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 16, image 2 of 2
      • Remove the ribbon connecting the keyboard to the motherboard.
      • You may now fully lift the front panel from the rest of the laptop.
      Ask FixBot
    1. HP Pavilion 17-f004dx Screen Replacement, Screen: step 17, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement, Screen: step 17, image 2 of 2
      • There is a metal component connecting the screen to the casing underneath each hinge.
      • Remove three 5.6 mm screws with a Phillips 1 screwdriver on each side.
      Ask FixBot
    2. HP Pavilion 17-f004dx Screen Replacement: step 18, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 18, image 2 of 2
      • Lift the black retaining flap to remove the black cable connecting the screen to the motherboard.
      Ask FixBot
    3. HP Pavilion 17-f004dx Screen Replacement: step 19, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 19, image 2 of 2
      • Gently remove the black ribbon that was connected to the black flap.
      Ask FixBot
    4. HP Pavilion 17-f004dx Screen Replacement: step 20, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 20, image 2 of 2
      • Locate the thin black wire that trails from the screen and remove it from the motherboard.
      Ask FixBot
    5. HP Pavilion 17-f004dx Screen Replacement: step 21, image 1 of 1
      • Remove two small rubber covers on the bottom right and left edges of the screen enclosure using a metal spudger to expose two screws.
      Ask FixBot
    6. HP Pavilion 17-f004dx Screen Replacement: step 22, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 22, image 2 of 2
      • Remove one 5.6mm screw with a Phillips 1 screwdriver from each side of the bottom screen.
      Ask FixBot
    7. HP Pavilion 17-f004dx Screen Replacement: step 23, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 23, image 2 of 2
      • Use a metal spudger to remove the plastic casing from the perimeter of the screen.
      Ask FixBot
    8. HP Pavilion 17-f004dx Screen Replacement: step 24, image 1 of 3 HP Pavilion 17-f004dx Screen Replacement: step 24, image 2 of 3 HP Pavilion 17-f004dx Screen Replacement: step 24, image 3 of 3
      • Be careful not to damage the wires.
      • Use a metal spudger to partially remove the screen from the plastic case.
      Ask FixBot
    9. HP Pavilion 17-f004dx Screen Replacement: step 25, image 1 of 2 HP Pavilion 17-f004dx Screen Replacement: step 25, image 2 of 2
      • Do not touch the circuit board directly.
      • Flip the screen over and remove the tape that holds down the ribbon.
      Ask FixBot
    10. HP Pavilion 17-f004dx Screen Replacement: step 26, image 1 of 1
      • Pull the ribbon away from the screen.
      Ask FixBot
Chi Huynh
726 Reputation
2 Guides authored
UC Davis, Team 1-4, Oliver Fall 2016 Member of UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Members
95 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,938
