HP Pavilion 17-f004dx Front Panel Replacement
    1. HP Pavilion 17-f004dx Front Panel Replacement, Battery: step 1, image 1 of 1
      • Before you remove the battery, make sure the laptop is powered off.
      • Slide the black battery latches inward to remove the battery.
      Ask FixBot
    2. HP Pavilion 17-f004dx Front Panel Replacement: step 2, image 1 of 1
      • Pull the battery out towards you while your fingers are still holding the latches in place.
      Ask FixBot
    1. HP Pavilion 17-f004dx Front Panel Replacement, CD Drive: step 3, image 1 of 1
      • Remove one 7 mm screw with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Pavilion 17-f004dx Front Panel Replacement: step 4, image 1 of 3 HP Pavilion 17-f004dx Front Panel Replacement: step 4, image 2 of 3 HP Pavilion 17-f004dx Front Panel Replacement: step 4, image 3 of 3
      • Use a metal spudger to push the CD drive out of its slot for removal.
      Ask FixBot
    1. HP Pavilion 17-f004dx Front Panel Replacement, Front Panel: step 5, image 1 of 1
      • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Pavilion 17-f004dx Front Panel Replacement: step 6, image 1 of 2 HP Pavilion 17-f004dx Front Panel Replacement: step 6, image 2 of 2
      • Remove the thin plastic cover using the flat metal spudger to expose another screw.
      • Remove one 7 mm screw with a Phillips #0 screwdriver.
      Ask FixBot
    3. HP Pavilion 17-f004dx Front Panel Replacement: step 7, image 1 of 2 HP Pavilion 17-f004dx Front Panel Replacement: step 7, image 2 of 2
      • Use a metal spudger to remove the rubber "feet" to expose two screws.
      Ask FixBot
    4. HP Pavilion 17-f004dx Front Panel Replacement: step 8, image 1 of 1
      • Underneath each rubber foot, there is a screw.
      • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
      Ask FixBot
    5. HP Pavilion 17-f004dx Front Panel Replacement: step 9, image 1 of 1
      • Remove the two black end caps to expose more screws.
      • The end caps will require some force to remove.
      Ask FixBot
    6. HP Pavilion 17-f004dx Front Panel Replacement: step 10, image 1 of 1
      • Remove the following six screws with a Phillips #1 screwdriver:
      • Two 7 mm screws.
      • Two 7 mm screws.
      • Two 4.8 mm screws.
      Ask FixBot
    7. HP Pavilion 17-f004dx Front Panel Replacement: step 11, image 1 of 1
      • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
      Ask FixBot
    8. HP Pavilion 17-f004dx Front Panel Replacement: step 12, image 1 of 2 HP Pavilion 17-f004dx Front Panel Replacement: step 12, image 2 of 2
      • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
      Ask FixBot
    9. HP Pavilion 17-f004dx Front Panel Replacement: step 13, image 1 of 1
      • Partially lift the top cover from the enclosure.
      Ask FixBot
    10. HP Pavilion 17-f004dx Front Panel Replacement: step 14, image 1 of 2 HP Pavilion 17-f004dx Front Panel Replacement: step 14, image 2 of 2
      • Remove the ribbon connecting the power button to the motherboard.
      Ask FixBot
    11. HP Pavilion 17-f004dx Front Panel Replacement: step 15, image 1 of 2 HP Pavilion 17-f004dx Front Panel Replacement: step 15, image 2 of 2
      • Remove the ribbon connecting the mousepad to the motherboard.
      Ask FixBot
    12. HP Pavilion 17-f004dx Front Panel Replacement: step 16, image 1 of 2 HP Pavilion 17-f004dx Front Panel Replacement: step 16, image 2 of 2
      • Remove the ribbon connecting the keyboard to the motherboard.
      • You may now fully lift the front panel from the rest of the laptop.
      Ask FixBot
Allan Soria
665 Reputation
4 Guides authored
UC Davis, Team 1-4, Oliver Fall 2016 Member of UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Members
95 Guides authored
1 Guide Comment
I need the fan , how much?
محمد السيد - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,629
