HP Pavilion 17-e117dx WLAN Module Replacement
    1. HP Pavilion 17-e117dx WLAN Module Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside down, so that the bottom is facing up.
      Ask FixBot
    2. HP Pavilion 17-e117dx WLAN Module Replacement: step 2, image 1 of 2 HP Pavilion 17-e117dx WLAN Module Replacement: step 2, image 2 of 2
      • Slide the battery release latch to the left. The battery will pop up slightly.
      • Lift the battery upwards and out of the laptop.
      Ask FixBot
    1. HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: step 3, image 1 of 2 HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: step 3, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
      Ask FixBot
    2. HP Pavilion 17-e117dx WLAN Module Replacement: step 4, image 1 of 1
      • Slide the service panel towards you to loosen it from the laptop.
      Ask FixBot
    3. HP Pavilion 17-e117dx WLAN Module Replacement: step 5, image 1 of 1
      • Remove the service panel.
      Ask FixBot
    1. HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: step 6, image 1 of 3 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: step 6, image 2 of 3 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: step 6, image 3 of 3
      • Remove the two antenna cables from the top of the WLAN module by pulling them upwards.
      • Be gentle when removing the cables. You don't want to damage them.
      Ask FixBot
    2. HP Pavilion 17-e117dx WLAN Module Replacement: step 7, image 1 of 2 HP Pavilion 17-e117dx WLAN Module Replacement: step 7, image 2 of 2
      • Remove the single Phillips PM 2.5 x 3.25 screw so that you can remove the WLAN module from the system board.
      • Use the Phillips #00 screwdriver.
      Ask FixBot
    3. HP Pavilion 17-e117dx WLAN Module Replacement: step 8, image 1 of 1
      • To remove the WLAN module, pull it away from the slot at an angle.
      Ask FixBot
Marcel Amazan
594 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 56
All Time: 770
