HP Pavilion 17-ak008cy Fan Replacement
    1. HP Pavilion 17-ak008cy Fan Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over so that the underside is facing you.
      Ask FixBot
    2. HP Pavilion 17-ak008cy Fan Replacement: step 2, image 1 of 3 HP Pavilion 17-ak008cy Fan Replacement: step 2, image 2 of 3 HP Pavilion 17-ak008cy Fan Replacement: step 2, image 3 of 3
      • Using your hands, push the two tabs inwards to release the battery.
      • Remove the battery from the device.
      Ask FixBot
    1. HP Pavilion 17-ak008cy Fan Replacement, Back Panel: step 3, image 1 of 3 HP Pavilion 17-ak008cy Fan Replacement, Back Panel: step 3, image 2 of 3 HP Pavilion 17-ak008cy Fan Replacement, Back Panel: step 3, image 3 of 3
      • Remove eleven screws from the back panel.
      • Remove the optical drive from the side.
      • Remove the back panel from the device.
      Ask FixBot
    1. HP Pavilion 17-ak008cy Fan Replacement, Fan: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the single screw securing the fan to the motherboard.
      Ask FixBot
    2. HP Pavilion 17-ak008cy Fan Replacement: step 5, image 1 of 2 HP Pavilion 17-ak008cy Fan Replacement: step 5, image 2 of 2
      • Disconnect the fan wire carefully so that the fan is longer connected to the motherboard.
      Ask FixBot
    3. HP Pavilion 17-ak008cy Fan Replacement: step 6, image 1 of 2 HP Pavilion 17-ak008cy Fan Replacement: step 6, image 2 of 2
      • Remove the fan from the device.
      Ask FixBot
Mohammad Alchaar
109 Reputation
1 Guide authored
UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G2
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 462
