HP Pavilion 17 TS Hard Drive Replacement
    1. HP Pavilion 17 TS Hard Drive Replacement, Battery: step 1, image 1 of 3 HP Pavilion 17 TS Hard Drive Replacement, Battery: step 1, image 2 of 3 HP Pavilion 17 TS Hard Drive Replacement, Battery: step 1, image 3 of 3
      • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
      Ask FixBot
    1. HP Pavilion 17 TS Hard Drive Replacement, Rear Cover: step 2, image 1 of 3 HP Pavilion 17 TS Hard Drive Replacement, Rear Cover: step 2, image 2 of 3 HP Pavilion 17 TS Hard Drive Replacement, Rear Cover: step 2, image 3 of 3
      • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
      • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
      • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
      Ask FixBot
    1. HP Pavilion 17 TS Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 HP Pavilion 17 TS Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 HP Pavilion 17 TS Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
      • Remove the two silver phillips screws from the hard drive.
      • Using the plastic tab, remove the hard drive from its socket.
      • Unplug the hard drive from the wire connecting it to the motherboard.
      Ask FixBot
Sean Croft
739 Reputation
5 Guides authored
UMass Dartmouth, Team 1-6, Miles Spring 2016 Member of UMass Dartmouth, Team 1-6, Miles Spring 2016
UMASSD-MILES-S16S1G6
3 Members
104 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 2,656
