HP Pavilion 15-p046nr Integrated Keyboard Replacement
    1. HP Pavilion 15-p046nr Integrated Keyboard Replacement, Battery: step 1, image 1 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Battery: step 1, image 2 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Battery: step 1, image 3 of 3
      • Flip the laptop over so the bottom is facing up.
      • Place your finger on the top left-hand slide button with the lock symbol.
      • Moving the slide does require some force.
      • Slide the button to the right so that an unlocked symbol is visible.
      Ask FixBot
    2. HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 2, image 1 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 2, image 2 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 2, image 3 of 3
      • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
      • Slide the button to the left.
      • Moving the slide will require some force.
      • Lift the battery off the computer with your thumb.
      • You will not need to slide the right button with the battery to reinstall the battery.
      Ask FixBot
    1. HP Pavilion 15-p046nr Integrated Keyboard Replacement, Integrated Keyboard: step 3, image 1 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Integrated Keyboard: step 3, image 2 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Integrated Keyboard: step 3, image 3 of 3
      • Remove screw covers from the hinge covers on the upper left and right side.
      • Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
      • Remove hinge covers by pulling up and out on the top of the cover.
      Ask FixBot
    2. HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 4, image 1 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 4, image 2 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 4, image 3 of 3
      • Remove thirteen 7 mm screws from the back panel using the Phillips #00 screwdriver.
      • Remove three 5 mm screws from the back panel using the Phillips #00 screwdriver.
      • Grab the disk drive on the left side and pull the disk drive out completely.
      • Flip the laptop over and open the display.
      Ask FixBot
    3. HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 5, image 1 of 2 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 5, image 2 of 2
      • Run the plastic opening tool along the entire edge of the keyboard to separate the keyboard from the base of the laptop.
      • Gently lift the keyboard tray up.
      • Use care to lift the keyboard off of the device. The keyboard is still attached by ribbon cables.
      Ask FixBot
    4. HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 6, image 1 of 2 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 6, image 2 of 2
      • Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the two ribbon cables connecting the keyboard to the device.
      • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
      • Grab the ribbon cable and gently pull away from the socket.
      • To reinstall, insert the ribbon cable into the connector and close the flap on the black line.
      Ask FixBot
    5. HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 7, image 1 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 7, image 2 of 3 HP Pavilion 15-p046nr Integrated Keyboard Replacement: step 7, image 3 of 3
      • Lift the keyboard up and away from the device.
      • Removing the keyboard exposes the motherboard and its sensitive components. Ensure no tools or items are set on the motherboard or it could cause damage.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 33
All Time: 1,867
