HP Pavilion 15-p Palmrest Replacement
    1. HP Pavilion 15-p Palmrest Replacement, Change note: step 1, image 1 of 2 HP Pavilion 15-p Palmrest Replacement, Change note: step 1, image 2 of 2
      Tool used on this step:
      Essential Electronics Toolkit
      $29.95
      Buy
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Ask FixBot
    1. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: step 2, image 1 of 3 HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: step 2, image 2 of 3 HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: step 2, image 3 of 3
      • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
      Ask FixBot
    2. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: step 3, image 1 of 3 HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: step 3, image 2 of 3 HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: step 3, image 3 of 3
      • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
      Ask FixBot
    3. HP Pavilion 15-p Palmrest Replacement, Remove the battery: step 4, image 1 of 2 HP Pavilion 15-p Palmrest Replacement, Remove the battery: step 4, image 2 of 2
      • Remove the battery. Pull the battery forward and remove it from the laptop.
      Ask FixBot
    1. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: step 5, image 1 of 3 HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: step 5, image 2 of 3 HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: step 5, image 3 of 3
      • EET owners: Your kit has this bit. No purchase needed.
      • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
      Ask FixBot
    2. HP Pavilion 15-p Palmrest Replacement, Remove the screws under the optical drive: step 6, image 1 of 1
      • The system used in the guide only came with one screw. If yours came with three, sort accordingly.
      • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
      Ask FixBot
    3. HP Pavilion 15-p Palmrest Replacement, Remove the bottom screws: step 7, image 1 of 1
      • Once the battery and optical drive are removed, remove the 11 Phillips #0 screws that secure the palmrest.
      • This screw is hidden by a sticker. If lost/damaged, it is cosmetic.
      • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
      Ask FixBot
    4. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: step 8, image 1 of 3 HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: step 8, image 2 of 3 HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: step 8, image 3 of 3
      • If you choose to reuse the original pads, stick them to the hinge caps to preserve the adhesive.
      • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
      • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
      Ask FixBot
    5. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: step 9, image 1 of 3 HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: step 9, image 2 of 3 HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: step 9, image 3 of 3
      • EET owners: Your kit has the needed picks. No purchase needed.
      • Do not fully remove the palmrest - the power button is still connected to the motherboard.
      • If you are having trouble removing the palmrest, try using a guitar pick.
      • Run a plastic tool around all 3 sides of the palmrest. Once they are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up and disconnect the cables.
      • Once the keyboard and trackpad are disconnected, the palmrest can be lifted up. In some cases, further prying may be needed.
      Ask FixBot
    6. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: step 10, image 1 of 3 HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: step 10, image 2 of 3 HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: step 10, image 3 of 3
      • With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up with a spudger and remove the palmrest.
      Ask FixBot
7 other people completed this guide.
Nick
105,731 Reputation
72 Guides authored
6 Guide Comments
My power button is bad and my mouse track stopped working. I couldn't find a replacement for it. What can I do?
Trevor Gilbert - Reply Share
hi where can i source a replacement palm rest assembly for my hp pavilion 15 2015. its the same as the first laptop picture
Oche Ejiga - Reply Share
You have the US ENG keyboard most likely. I posted the parts list as new steps (762529-001 or 762530-001). Verify it based on the part number sticker to be absolutely sure though but that is likely a match.
Nick - Reply Share
Hi my hinge broke off and so was some of my speaker. Plus, its making my screen close on its own and I can't keep it still. :( Where can I get a replacement for the palmrest, keyboard, and touchpad? My model for my hp pavillion laptop is: 3C310UA#ABA
thecrowrules1982 - Reply Share
Parts laptop, or a junk laptop with a bad motherboard (BIOS lock or dead power). The bare part tends to be ~$150+ if it's available and will only get worse as they become hard to find.
Nick - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 105
All Time: 8,744
