HP Pavilion 15-eg RAM Replacement
    1. HP Pavilion 15-eg RAM Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Fully shut down your laptop and unplug all cables.
      Ask FixBot
    1. HP Pavilion 15-eg RAM Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. HP Pavilion 15-eg RAM Replacement, Expose the back cover screws: step 3, image 1 of 3 HP Pavilion 15-eg RAM Replacement, Expose the back cover screws: step 3, image 2 of 3 HP Pavilion 15-eg RAM Replacement, Expose the back cover screws: step 3, image 3 of 3
      • The ends of the rubber feet cover four back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
      • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
      Ask FixBot
    3. HP Pavilion 15-eg RAM Replacement: step 4, image 1 of 3 HP Pavilion 15-eg RAM Replacement: step 4, image 2 of 3 HP Pavilion 15-eg RAM Replacement: step 4, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Peel up the other ends of the feet to expose the three remaining screws.
      • During reassembly:
      • Press down firmly on the ends of the feet to secure them into their recesses.
      • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
      Ask FixBot
    4. HP Pavilion 15-eg RAM Replacement, Unfasten the back cover: step 5, image 1 of 2 HP Pavilion 15-eg RAM Replacement, Unfasten the back cover: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the six screws securing the back cover:
      • Four larger 6.6 mm-long black screws
      • Two smaller 4.8 mm-long silver screws
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      Ask FixBot
    5. HP Pavilion 15-eg RAM Replacement, Release the clips: step 6, image 1 of 2 HP Pavilion 15-eg RAM Replacement, Release the clips: step 6, image 2 of 2
      • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
      • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the left of the right hinge.
      • Pry up with the spudger to release the clips securing the top right corner of the back cover.
      Ask FixBot
    6. HP Pavilion 15-eg RAM Replacement: step 7, image 1 of 3 HP Pavilion 15-eg RAM Replacement: step 7, image 2 of 3 HP Pavilion 15-eg RAM Replacement: step 7, image 3 of 3
      • Insert the flat end of a spudger between the top right corner of the back cover and frame.
      • Slide the spudger down to the bottom right corner to release the clips on the right edge.
      Ask FixBot
    7. HP Pavilion 15-eg RAM Replacement: step 8, image 1 of 3 HP Pavilion 15-eg RAM Replacement: step 8, image 2 of 3 HP Pavilion 15-eg RAM Replacement: step 8, image 3 of 3
      • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
      • Slide the spudger to the bottom left corner to release the clips.
      Ask FixBot
    8. HP Pavilion 15-eg RAM Replacement: step 9, image 1 of 3 HP Pavilion 15-eg RAM Replacement: step 9, image 2 of 3 HP Pavilion 15-eg RAM Replacement: step 9, image 3 of 3
      • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
      • Slide the spudger up to the top left corner to release the clips on the left edge.
      Ask FixBot
    9. HP Pavilion 15-eg RAM Replacement: step 10, image 1 of 3 HP Pavilion 15-eg RAM Replacement: step 10, image 2 of 3 HP Pavilion 15-eg RAM Replacement: step 10, image 3 of 3
      • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the right of the left hinge.
      • Slide the spudger towards the right hinge to release the remaining clips.
      Ask FixBot
    10. HP Pavilion 15-eg RAM Replacement, Remove the back cover: step 11, image 1 of 3 HP Pavilion 15-eg RAM Replacement, Remove the back cover: step 11, image 2 of 3 HP Pavilion 15-eg RAM Replacement, Remove the back cover: step 11, image 3 of 3
      • Remove the back cover.
      • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
      Ask FixBot
    1. HP Pavilion 15-eg RAM Replacement, Unfasten the battery: step 12, image 1 of 2 HP Pavilion 15-eg RAM Replacement, Unfasten the battery: step 12, image 2 of 2
      • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
      • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
      • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the battery.
      Ask FixBot
    2. HP Pavilion 15-eg RAM Replacement, Remove the battery: step 13, image 1 of 3 HP Pavilion 15-eg RAM Replacement, Remove the battery: step 13, image 2 of 3 HP Pavilion 15-eg RAM Replacement, Remove the battery: step 13, image 3 of 3
      • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
      • Remove the battery.
      • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      Ask FixBot
    1. HP Pavilion 15-eg RAM Replacement, Unlatch the RAM: step 14, image 1 of 3 HP Pavilion 15-eg RAM Replacement, Unlatch the RAM: step 14, image 2 of 3 HP Pavilion 15-eg RAM Replacement, Unlatch the RAM: step 14, image 3 of 3
      • Your laptop has two memory slots, each with a pair of metal arms that secure a stick of RAM.
      • Simultaneously push out the metal arms on each side of a stick of RAM until they disengage and the stick pops up at a slight angle.
      Ask FixBot
    2. HP Pavilion 15-eg RAM Replacement, Remove the RAM: step 15, image 1 of 3 HP Pavilion 15-eg RAM Replacement, Remove the RAM: step 15, image 2 of 3 HP Pavilion 15-eg RAM Replacement, Remove the RAM: step 15, image 3 of 3
      • Pull the stick of RAM out of its socket to remove it.
      • Repeat for a second stick of RAM.
      • To install a memory module, insert it into its socket at a slight downward angle, then push down firmly until both metal arms lock the RAM in place.
      Ask FixBot
5 other people completed this guide.
Spencer Day
206,396 Reputation
1,268 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 50
Past 30 Days: 186
All Time: 3,811
