HP Pavilion 15-eg Fan Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
10
Past 7 Days:
41
Past 30 Days:
194
All Time:
3,699
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Use this guide to clean or replace the fan in your HP Pavilion 15 Laptop PC.
Note: This procedure was written using a model 15-eg2015od HP 15 Pavilion Laptop PC, but is fully compatible with any HP 15 Pavilion Laptop PC whose model number starts with 15-eg or 15-eh.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. HP Pavilion 15-eg Fan Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Fully shut down your laptop and unplug all cables.
      Ask FixBot
    1. HP Pavilion 15-eg Fan Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. HP Pavilion 15-eg Fan Replacement, Expose the back cover screws: step 3, image 1 of 3 HP Pavilion 15-eg Fan Replacement, Expose the back cover screws: step 3, image 2 of 3 HP Pavilion 15-eg Fan Replacement, Expose the back cover screws: step 3, image 3 of 3
      • The ends of the rubber feet cover four back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
      • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
      Ask FixBot
    3. HP Pavilion 15-eg Fan Replacement: step 4, image 1 of 3 HP Pavilion 15-eg Fan Replacement: step 4, image 2 of 3 HP Pavilion 15-eg Fan Replacement: step 4, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Peel up the other ends of the feet to expose the three remaining screws.
      • During reassembly:
      • Press down firmly on the ends of the feet to secure them into their recesses.
      • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
      Ask FixBot
    4. HP Pavilion 15-eg Fan Replacement, Unfasten the back cover: step 5, image 1 of 2 HP Pavilion 15-eg Fan Replacement, Unfasten the back cover: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the six screws securing the back cover:
      • Four larger 6.6 mm-long black screws
      • Two smaller 4.8 mm-long silver screws
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      Ask FixBot
    5. HP Pavilion 15-eg Fan Replacement, Release the clips: step 6, image 1 of 2 HP Pavilion 15-eg Fan Replacement, Release the clips: step 6, image 2 of 2
      • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
      • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the left of the right hinge.
      • Pry up with the spudger to release the clips securing the top right corner of the back cover.
      Ask FixBot
    6. HP Pavilion 15-eg Fan Replacement: step 7, image 1 of 3 HP Pavilion 15-eg Fan Replacement: step 7, image 2 of 3 HP Pavilion 15-eg Fan Replacement: step 7, image 3 of 3
      • Insert the flat end of a spudger between the top right corner of the back cover and frame.
      • Slide the spudger down to the bottom right corner to release the clips on the right edge.
      Ask FixBot
    7. HP Pavilion 15-eg Fan Replacement: step 8, image 1 of 3 HP Pavilion 15-eg Fan Replacement: step 8, image 2 of 3 HP Pavilion 15-eg Fan Replacement: step 8, image 3 of 3
      • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
      • Slide the spudger to the bottom left corner to release the clips.
      Ask FixBot
    8. HP Pavilion 15-eg Fan Replacement: step 9, image 1 of 3 HP Pavilion 15-eg Fan Replacement: step 9, image 2 of 3 HP Pavilion 15-eg Fan Replacement: step 9, image 3 of 3
      • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
      • Slide the spudger up to the top left corner to release the clips on the left edge.
      Ask FixBot
    9. HP Pavilion 15-eg Fan Replacement: step 10, image 1 of 3 HP Pavilion 15-eg Fan Replacement: step 10, image 2 of 3 HP Pavilion 15-eg Fan Replacement: step 10, image 3 of 3
      • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the right of the left hinge.
      • Slide the spudger towards the right hinge to release the remaining clips.
      Ask FixBot
    10. HP Pavilion 15-eg Fan Replacement, Remove the back cover: step 11, image 1 of 3 HP Pavilion 15-eg Fan Replacement, Remove the back cover: step 11, image 2 of 3 HP Pavilion 15-eg Fan Replacement, Remove the back cover: step 11, image 3 of 3
      • Remove the back cover.
      • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
      Ask FixBot
    1. HP Pavilion 15-eg Fan Replacement, Unfasten the battery: step 12, image 1 of 2 HP Pavilion 15-eg Fan Replacement, Unfasten the battery: step 12, image 2 of 2
      • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
      • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
      • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the battery.
      Ask FixBot
    2. HP Pavilion 15-eg Fan Replacement, Remove the battery: step 13, image 1 of 3 HP Pavilion 15-eg Fan Replacement, Remove the battery: step 13, image 2 of 3 HP Pavilion 15-eg Fan Replacement, Remove the battery: step 13, image 3 of 3
      • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
      • Remove the battery.
      • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      Ask FixBot
    1. HP Pavilion 15-eg Fan Replacement, Disconnect the fan cable: step 14, image 1 of 3 HP Pavilion 15-eg Fan Replacement, Disconnect the fan cable: step 14, image 2 of 3 HP Pavilion 15-eg Fan Replacement, Disconnect the fan cable: step 14, image 3 of 3
      • Use the pointed end of a spudger to push on each side of the fan cable connector, alternating sides to "walk" it out of its socket.
      Ask FixBot
    2. HP Pavilion 15-eg Fan Replacement, Unfasten the fan: step 15, image 1 of 2 HP Pavilion 15-eg Fan Replacement, Unfasten the fan: step 15, image 2 of 2
      • Use a Phillips screwdriver to remove the three 3.8 mm-long screws securing the fan.
      Ask FixBot
    3. HP Pavilion 15-eg Fan Replacement, Remove the fan: step 16, image 1 of 2 HP Pavilion 15-eg Fan Replacement, Remove the fan: step 16, image 2 of 2
      • Remove the fan.
      • For models with two fans:
      • Repeat the previous two steps to disconnect, unscrew, and remove the second fan.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
3 other people completed this guide.
Spencer Day
206,591 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 41
Past 30 Days: 194
All Time: 3,699
