HP Pavilion 15-e043cl Wi-Fi Card Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
62
All Time:
496
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your HP Pavilion 15-e043cl isn't able to connect to Wi-Fi, and it is able to be powered on and is functionally normal otherwise, then the laptop may have a faulty Wi-Fi card.
Check to make sure that the laptop is not detecting any Wi-Fi networks whatsoever in the Wi-Fi network settings area. If networks are showing up, then the router itself is most likely the issue and not the laptop. Otherwise, this guide will show how to replace the Wi-Fi card.
The Wi-Fi card locates Wi-Fi networks for your device to connect, and it will connect you to the internet depending on what network you choose and connect to. A faulty card will not be able to locate networks even within the vicinity of local networks.
Before beginning, make sure to power off the device completely, and disconnect and charge adapters and other power sources.
Tools
    1. HP Pavilion 15-e043cl Wi-Fi Card Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-e043cl Wi-Fi Card Replacement, Battery: step 1, image 2 of 2
      • Flip the device over.
      • Slide the battery switch on the right half of the laptop.
      • Make sure the device is powered off, and that it is not connected to any power sources.
      Ask FixBot
    2. HP Pavilion 15-e043cl Wi-Fi Card Replacement: step 2, image 1 of 2 HP Pavilion 15-e043cl Wi-Fi Card Replacement: step 2, image 2 of 2
      • Lift the battery up and out of the device by the inward-facing edge.
      Ask FixBot
    1. HP Pavilion 15-e043cl Wi-Fi Card Replacement, Maintenance Panel: step 3, image 1 of 3 HP Pavilion 15-e043cl Wi-Fi Card Replacement, Maintenance Panel: step 3, image 2 of 3 HP Pavilion 15-e043cl Wi-Fi Card Replacement, Maintenance Panel: step 3, image 3 of 3
      • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
      • The screw can not, and should not, be fully removed.
      • Slide the maintenance panel away from the battery compartment to release it.
      Ask FixBot
    1. HP Pavilion 15-e043cl Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the white and black mini jumper cable attached to the Wi-Fi card.
      Ask FixBot
    2. HP Pavilion 15-e043cl Wi-Fi Card Replacement: step 5, image 1 of 2 HP Pavilion 15-e043cl Wi-Fi Card Replacement: step 5, image 2 of 2
      • Remove the single 2.5 mm screw with a Phillips #0 screwdriver from the Wi-Fi card.
      • Lift the Wi-Fi card out of the device.
      Ask FixBot
Cace Letendre
528 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 4-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G5
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 62
All Time: 496
