Up to 20% off select tools
HP Pavilion 15-e043cl Keyboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
79
All Time:
731
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will help you replace the keyboard on your HP Pavilion 15-e043cl laptop.
The keyboard is used to input information into your laptop. The keyboard on this laptop is a self-contained unit which can be easily removed and replaced. Through regular use, your laptop may begin missing keystrokes when you are typing, or the keyboard could become completely unresponsive.
If you have these symptoms you may want to replace your keyboard by following this guide.
    1. HP Pavilion 15-e043cl Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Open the laptop.
      Ask FixBot
    2. HP Pavilion 15-e043cl Keyboard Replacement: step 2, image 1 of 2 HP Pavilion 15-e043cl Keyboard Replacement: step 2, image 2 of 2
      • Use a spudger to pry the keyboard from the laptop.
      • Make your way around the keyboard, lifting the keyboard out as you go.
      Ask FixBot
    3. HP Pavilion 15-e043cl Keyboard Replacement: step 3, image 1 of 2 HP Pavilion 15-e043cl Keyboard Replacement: step 3, image 2 of 2
      • Reach under the keyboard and disconnect the ribbon cable from the laptop.
      • Take note of the replacement part number on the back of the keyboard.
      Ask FixBot
Author
with
Cace Letendre
528 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 4-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G5
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 79
All Time: 731
