HP Pavilion 15-d035dx RAM Replacement
    1. HP Pavilion 15-d035dx RAM Replacement, Battery: step 1, image 1 of 3 HP Pavilion 15-d035dx RAM Replacement, Battery: step 1, image 2 of 3 HP Pavilion 15-d035dx RAM Replacement, Battery: step 1, image 3 of 3
      • Switch the first lock, with the padlock icon, to the open position.
      • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
      Ask FixBot
    1. HP Pavilion 15-d035dx RAM Replacement, Back Panel: step 2, image 1 of 1
      • Flip the laptop so that the back is facing upwards.
      • Locate the small screw on the back that holds the "L" shaped panel.
      • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
      Ask FixBot
    2. HP Pavilion 15-d035dx RAM Replacement: step 3, image 1 of 3 HP Pavilion 15-d035dx RAM Replacement: step 3, image 2 of 3 HP Pavilion 15-d035dx RAM Replacement: step 3, image 3 of 3
      • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
      • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
      Ask FixBot
    3. HP Pavilion 15-d035dx RAM Replacement: step 4, image 1 of 1
      • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
      Ask FixBot
    1. HP Pavilion 15-d035dx RAM Replacement, RAM: step 5, image 1 of 1
      • Locate the RAM, it is about a 2 inch by 1 inch rectangle that is blue in color.
      Ask FixBot
    2. HP Pavilion 15-d035dx RAM Replacement: step 6, image 1 of 1
      • Press down on the small silver latches on either side of the RAM, the RAM should pop up. While doing this you will hear a faint click.
      Ask FixBot
    3. HP Pavilion 15-d035dx RAM Replacement: step 7, image 1 of 1
      • Finally remove the RAM by pulling it away from the black connection panel.
      • Once the RAM is removed you can put in the replacement RAM.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 97
All Time: 933
