HP Pavilion 15-d035dx Front Panel Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
111
All Time:
1,568
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HP Pavilion 15-d035dx Front Panel Replacement, Battery: step 1, image 1 of 3 HP Pavilion 15-d035dx Front Panel Replacement, Battery: step 1, image 2 of 3 HP Pavilion 15-d035dx Front Panel Replacement, Battery: step 1, image 3 of 3
      • Switch the first lock, with the padlock icon, to the open position.
      • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
      Ask FixBot
    1. HP Pavilion 15-d035dx Front Panel Replacement, Front Panel: step 2, image 1 of 1
      • Begin by laying the laptop on its backside with the bottom of the laptop facing you.
      Ask FixBot
    2. HP Pavilion 15-d035dx Front Panel Replacement: step 3, image 1 of 2 HP Pavilion 15-d035dx Front Panel Replacement: step 3, image 2 of 2
      • There will be 11, 2.5x3.0mm Philips head screws that you will need to locate.
      • Continue by unscrewing all of them using a 0 Phillips screwdriver.
      Ask FixBot
    3. HP Pavilion 15-d035dx Front Panel Replacement: step 4, image 1 of 3 HP Pavilion 15-d035dx Front Panel Replacement: step 4, image 2 of 3 HP Pavilion 15-d035dx Front Panel Replacement: step 4, image 3 of 3
      • Take off the back panel by removing the 4.0x4.7mm Philips head screw.
      • Then using the opening tool, work around the edges to pull off the back panel.
      • It will take some force to get the back panel off.
      Ask FixBot
    4. HP Pavilion 15-d035dx Front Panel Replacement: step 5, image 1 of 1
      • Now flip the computer right side up and open up the laptop.
      • You should be facing the screen and keyboard.
      Ask FixBot
    5. HP Pavilion 15-d035dx Front Panel Replacement: step 6, image 1 of 1
      • Now using the opening tool remove the front panel from the back panel.
      • It should start to pop off, you will have to do this step around the entire computer.
      • It will give some resistance so take your time to ensure that nothing breaks.
      Ask FixBot
    6. HP Pavilion 15-d035dx Front Panel Replacement: step 7, image 1 of 1
      • Once you have popped off the panel it should simply be able to lift off of the laptop.
      • Keep in mind that the keyboard is still connected to the motherboard. Simply lay the keyboard on top of the screen while you are completing future guides.
      • You can replace the front panel now.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 111
All Time: 1,568
