HP Pavilion 15-d035dx Disk Drive Replacement
    1. HP Pavilion 15-d035dx Disk Drive Replacement, Battery: step 1, image 1 of 3 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: step 1, image 2 of 3 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: step 1, image 3 of 3
      • Switch the first lock, with the padlock icon, to the open position.
      • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
      Ask FixBot
    1. HP Pavilion 15-d035dx Disk Drive Replacement, Back Panel: step 2, image 1 of 1
      • Flip the laptop so that the back is facing upwards.
      • Locate the small screw on the back that holds the "L" shaped panel.
      • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
      Ask FixBot
    2. HP Pavilion 15-d035dx Disk Drive Replacement: step 3, image 1 of 3 HP Pavilion 15-d035dx Disk Drive Replacement: step 3, image 2 of 3 HP Pavilion 15-d035dx Disk Drive Replacement: step 3, image 3 of 3
      • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
      • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
      Ask FixBot
    3. HP Pavilion 15-d035dx Disk Drive Replacement: step 4, image 1 of 1
      • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
      Ask FixBot
    1. HP Pavilion 15-d035dx Disk Drive Replacement, Disk Drive: step 5, image 1 of 1
      • Once you have removed the panel there is one screw (2.5x6mm) that will need to be unscrewed.
      Ask FixBot
    2. HP Pavilion 15-d035dx Disk Drive Replacement: step 6, image 1 of 2 HP Pavilion 15-d035dx Disk Drive Replacement: step 6, image 2 of 2
      • After unscrewing the back screw for the disc drive another 14 screws (2.5x6.0mm) will need to be removed.
      Ask FixBot
    3. HP Pavilion 15-d035dx Disk Drive Replacement: step 7, image 1 of 1
      • Now flip the computer back to right side up.
      • Using the plastic opening tool from iFixit to pry open the top half of laptop case. Take off the top half.
      Ask FixBot
    4. HP Pavilion 15-d035dx Disk Drive Replacement: step 8, image 1 of 2 HP Pavilion 15-d035dx Disk Drive Replacement: step 8, image 2 of 2
      • Now seeing the inside of the laptop. Unscrew one more screw (2.0x3.0mm).
      Ask FixBot
    5. HP Pavilion 15-d035dx Disk Drive Replacement: step 9, image 1 of 3 HP Pavilion 15-d035dx Disk Drive Replacement: step 9, image 2 of 3 HP Pavilion 15-d035dx Disk Drive Replacement: step 9, image 3 of 3
      • Now you should be able slide the disk drive out to the side.
      • Do not pull up on the disk drive. This could damage the plug ins and/or the case that help holds it all together.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,607
