HP Pavilion 15-cs3003ca Cooling Fan Replacement
    1. HP Pavilion 15-cs3003ca Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 1
      • Ensure the laptop is completely powered off before proceeding. Holding the power button for 10-15 seconds can help drain any residual power.
      • Unplug the power adapter, remove all connected peripherals (USB drives, external monitors, etc.), and place the laptop on a clean, static-free surface to avoid dust and static damage.
      • If available, wear an anti-static wrist strap to prevent electrostatic discharge (ESD) from damaging internal components.
      • If you don’t have an anti-static wrist strap, touch a metal surface before handling internal components to discharge static electricity.
      • Keep the power adapter and other accessories in a safe place so you can reconnect them later.
      Ask FixBot
    2. HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 2, image 1 of 2 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 2, image 2 of 2
      • Flip the laptop over so the bottom panel is facing up.
      • Use a Phillips #0 screwdriver to remove six 3.2 mm screws securing the back panel.
      • If your model has rubber feet, use tweezers to carefully lift them and reveal hidden screws underneath.
      • Insert a plastic card or opening tool along the edges of the back panel.
      • Gently slide the opening tool around the edges to release the clips.
      • Do not apply excessive force when prying, as plastic clips can break.
      • Once loosened, carefully lift the panel off and set it aside.
      Ask FixBot
    3. HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 3, image 1 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 3, image 2 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the five screws securing the battery to the laptop.
      • Gently lift the battery approximately 7 mm from the bottom edge, then slide it out of its connector on the motherboard.
      • Never use metal tools to pry the battery connector, as this could cause a short circuit or damage the connector pins.
      Ask FixBot
    4. HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 4, image 1 of 2 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 4, image 2 of 2
      • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • The fan connector is delicate. Do not pull on the wires, as this may damage them or the connector.
      Ask FixBot
    5. HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 5, image 1 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 5, image 2 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 5, image 3 of 3
      • Use a Phillips #0 screwdriver to remove three 2.5 mm screws that secure the fan to the board.
      • Carefully remove the fan and set it aside to clean the area if necessary.
      • Do not tilt or shake the fan excessively, as dust and debris inside may spread onto other components.
      • If you notice excessive dust in the cooling system, use compressed air to clean the area before installing the new fan.
      Ask FixBot
    6. HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 6, image 1 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 6, image 2 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 6, image 3 of 3
      • Carefully replace the fan without bending or pinching any cables.
      • Use a Phillips #0 screwdriver to secure the three 2.5 mm screws.
      • Ensure the fan is aligned correctly before tightening the screws. Over-tightening may cause damage to the fan or mounting points.
      • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
      • Don't push on the cables themselves, or you may damage the connector.
      Ask FixBot
    7. HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 7, image 1 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 7, image 2 of 3 HP Pavilion 15-cs3003ca Cooling Fan Replacement: step 7, image 3 of 3
      • Slide the battery back in so it plugs into the connector on the motherboard and secure the screws.
      • Replace the back panel and press it down gently around the edges to ensure the clips attach properly.
      • Use the Phillips #0 screwdriver to secure the six 3.2 mm screws.
      • Power on the laptop and listen for the fan running properly. Check system temperatures using software like HWMonitor or Core Temp to confirm that the cooling fan is working effectively.
      Ask FixBot
Sanya Garg
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 72
All Time: 677
