HP Pavilion 15-cs0012cl Fan Replacement
    1. HP Pavilion 15-cs0012cl Fan Replacement, Battery: step 1, image 1 of 3 HP Pavilion 15-cs0012cl Fan Replacement, Battery: step 1, image 2 of 3 HP Pavilion 15-cs0012cl Fan Replacement, Battery: step 1, image 3 of 3
      • Remove the three 5.6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
      • Remove the two rubber feet at the top of the case.
      • Remove the three 5.6mm hidden screws using a Phillips #0 screwdriver.
      • Insert a plastic pick between the bottom cover and the laptop chassis.
      • Slide the pick along the edges to detach the bottom cover, then lift it off.
      Ask FixBot
    2. HP Pavilion 15-cs0012cl Fan Replacement: step 2, image 1 of 3 HP Pavilion 15-cs0012cl Fan Replacement: step 2, image 2 of 3 HP Pavilion 15-cs0012cl Fan Replacement: step 2, image 3 of 3
      • Remove the two 4.3 mm screws securing the battery using a Phillips #0 screwdriver.
      • Lift the battery up and pull it away from the motherboard to remove it.
      Ask FixBot
    1. HP Pavilion 15-cs0012cl Fan Replacement, Fan: step 3, image 1 of 3 HP Pavilion 15-cs0012cl Fan Replacement, Fan: step 3, image 2 of 3 HP Pavilion 15-cs0012cl Fan Replacement, Fan: step 3, image 3 of 3
      • Unplug the cable connecting the fan to the motherboard.
      • Remove the three 4.4mm screws that hold the fan in place using a Phillips #0 screwdriver.
      Ask FixBot
    2. HP Pavilion 15-cs0012cl Fan Replacement: step 4, image 1 of 1
      • Lift the fan to remove it from the motherboard.
      Ask FixBot
Brandon Lopez
397 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 142
