HP Pavilion 15-cd040wm RAM Replacement
    1. HP Pavilion 15-cd040wm RAM Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 1 of 2 HP Pavilion 15-cd040wm RAM Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 2 of 2
      • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
      • If you have trouble gripping a tab, use a spudger to wedge it loose.
      Ask FixBot
    2. HP Pavilion 15-cd040wm RAM Replacement: step 2, image 1 of 2 HP Pavilion 15-cd040wm RAM Replacement: step 2, image 2 of 2
      • 3x 10mm Phillips scews
      • 2x 5mm Phillips screws
      • 6x 6mm Phillips screws
      • Remove all screws using a size Phillips #0 screwdriver.
      Ask FixBot
    3. HP Pavilion 15-cd040wm RAM Replacement: step 3, image 1 of 3 HP Pavilion 15-cd040wm RAM Replacement: step 3, image 2 of 3 HP Pavilion 15-cd040wm RAM Replacement: step 3, image 3 of 3
      • Using the iFixit opening tool, carefully pry along the sides of the back cover.
      • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
      • After everything is unclipped, you can safely remove the back cover from the rest of the device.
      Ask FixBot
    1. HP Pavilion 15-cd040wm RAM Replacement, Battery: step 4, image 1 of 2 HP Pavilion 15-cd040wm RAM Replacement, Battery: step 4, image 2 of 2
      • 2x 5mm Philips screws
      • 2x 3mm Philips screws
      Ask FixBot
    2. HP Pavilion 15-cd040wm RAM Replacement: step 5, image 1 of 2 HP Pavilion 15-cd040wm RAM Replacement: step 5, image 2 of 2
      • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
      • Pull out the battery at an angle and lift it out of the laptop.
      Ask FixBot
    1. HP Pavilion 15-cd040wm RAM Replacement, RAM: step 6, image 1 of 3 HP Pavilion 15-cd040wm RAM Replacement, RAM: step 6, image 2 of 3 HP Pavilion 15-cd040wm RAM Replacement, RAM: step 6, image 3 of 3
      • Pull the two tabs at the short ends of the RAM module with your fingers to release it, then pull the RAM module out of the slot.
      Ask FixBot
Brian Cornet
319 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 63
All Time: 1,490
