HP Pavilion 15-cd040wm Battery Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
72
All Time:
2,735
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your battery fails to charge or doesn't hold a charge long enough to be productive anymore, you most likely have a faulty battery that requires replacement.
To access the battery, you will first need to open your HP Pavilion 15-cd040wm by disassembling its back cover.
Before beginning, make sure to power off your laptop completely and disconnect it from any external power source.
Tools
    1. HP Pavilion 15-cd040wm Battery Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 1 of 2 HP Pavilion 15-cd040wm Battery Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 2 of 2
      • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
      • If you have trouble gripping a tab, use a spudger to wedge it loose.
      Ask FixBot
    2. HP Pavilion 15-cd040wm Battery Replacement: step 2, image 1 of 2 HP Pavilion 15-cd040wm Battery Replacement: step 2, image 2 of 2
      • 3x 10mm Phillips scews
      • 2x 5mm Phillips screws
      • 6x 6mm Phillips screws
      • Remove all screws using a size Phillips #0 screwdriver.
      Ask FixBot
    3. HP Pavilion 15-cd040wm Battery Replacement: step 3, image 1 of 3 HP Pavilion 15-cd040wm Battery Replacement: step 3, image 2 of 3 HP Pavilion 15-cd040wm Battery Replacement: step 3, image 3 of 3
      • Using the iFixit opening tool, carefully pry along the sides of the back cover.
      • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
      • After everything is unclipped, you can safely remove the back cover from the rest of the device.
      Ask FixBot
    1. HP Pavilion 15-cd040wm Battery Replacement, Battery: step 4, image 1 of 2 HP Pavilion 15-cd040wm Battery Replacement, Battery: step 4, image 2 of 2
      • 2x 5mm Philips screws
      • 2x 3mm Philips screws
      Ask FixBot
    2. HP Pavilion 15-cd040wm Battery Replacement: step 5, image 1 of 2 HP Pavilion 15-cd040wm Battery Replacement: step 5, image 2 of 2
      • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
      • Pull out the battery at an angle and lift it out of the laptop.
      Ask FixBot
Joe Krawczyk
397 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 72
All Time: 2,735
