HP Pavilion 15-cd040wm Back Cover Disassembly
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
146
All Time:
12,008
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In order to replace any faulty or outdated component (such as the battery, hard drive, CD drive, RAM, or screen), you will need to open your HP Pavilion 15-cd040wm by disassembling its back cover.
Before beginning, make sure to power off your laptop completely and disconnect it from any external power source.
Tools
    1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 1 of 2 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 2 of 2
      • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
      • If you have trouble gripping a tab, use a spudger to wedge it loose.
      Ask FixBot
    2. HP Pavilion 15-cd040wm Back Cover Disassembly: step 2, image 1 of 2 HP Pavilion 15-cd040wm Back Cover Disassembly: step 2, image 2 of 2
      • 3x 10mm Phillips scews
      • 2x 5mm Phillips screws
      • 6x 6mm Phillips screws
      • Remove all screws using a size Phillips #0 screwdriver.
      Ask FixBot
    3. HP Pavilion 15-cd040wm Back Cover Disassembly: step 3, image 1 of 3 HP Pavilion 15-cd040wm Back Cover Disassembly: step 3, image 2 of 3 HP Pavilion 15-cd040wm Back Cover Disassembly: step 3, image 3 of 3
      • Using the iFixit opening tool, carefully pry along the sides of the back cover.
      • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
      • After everything is unclipped, you can safely remove the back cover from the rest of the device.
      Ask FixBot
3 other people completed this guide.
Joe Krawczyk
397 Reputation
2 Guides authored
3 Guide Comments
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - Reply Share
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - Reply Share
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - Reply Share
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 146
All Time: 12,008
