HP Pavilion 15-ca2073cl SD Card Reader Replacement
Video Overview
    1. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Back Cover: step 1, image 1 of 1
      • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
      • Flip the laptop over.
      • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
      Ask FixBot
    2. HP Pavilion 15-ca2073cl SD Card Reader Replacement: step 2, image 1 of 2 HP Pavilion 15-ca2073cl SD Card Reader Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
      • Start from the front and work down both sides, disconnecting clips.
      • Remove the bottom case from the body.
      Ask FixBot
    1. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: step 3, image 1 of 2 HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: step 3, image 2 of 2
      • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
      Ask FixBot
    1. HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: step 4, image 1 of 3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: step 4, image 2 of 3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: step 4, image 3 of 3
      • Use a spudger to flip up the retaining flap securing the ribbon cable
      • Remove the white ribbon cable from its connector.
      Ask FixBot
    2. HP Pavilion 15-ca2073cl SD Card Reader Replacement: step 5, image 1 of 1
      • Remove the single silver 4.3 mm screw with a Phillips #0 screwdriver.
      Ask FixBot
    3. HP Pavilion 15-ca2073cl SD Card Reader Replacement: step 6, image 1 of 1
      • Remove the SD card reader from the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 587
