HP Pavilion 15-ba003ds Backplate Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
72
All Time:
917
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 - 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will detail how you can get into the HP Pavilion 15-ba003ds by providing you the steps to follow in order to safely remove the back plate from your laptop. This guide may be of use to you should you need to have access to the internal components of your laptop for any repair, replacements, or cleaning of the laptop.
Tools
    1. HP Pavilion 15-ba003ds Backplate Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-ba003ds Backplate Replacement, Battery: step 1, image 2 of 2
      • Unplug the AC adapter from the corresponding socket in the laptop.
      • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
      • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
      • Carefully slide the battery out of the laptop frame and place it somewhere safe.
      Ask FixBot
    1. HP Pavilion 15-ba003ds Backplate Replacement, Disc Drive: step 2, image 1 of 1
      • Use a spudger to remove the two rubber feet next to the battery.
      • This will reveal two hidden screws.
      • Save the feet for reassembly.
      Ask FixBot
    2. HP Pavilion 15-ba003ds Backplate Replacement: step 3, image 1 of 2 HP Pavilion 15-ba003ds Backplate Replacement: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove twelve 8 mm screws from the bottom of your laptop including the two screws found underneath the rubber feet.
      Ask FixBot
    3. HP Pavilion 15-ba003ds Backplate Replacement: step 4, image 1 of 2 HP Pavilion 15-ba003ds Backplate Replacement: step 4, image 2 of 2
      • Pull the disc drive from your laptop to remove it.
      Ask FixBot
    1. HP Pavilion 15-ba003ds Backplate Replacement, Backplate: step 5, image 1 of 3 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: step 5, image 2 of 3 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: step 5, image 3 of 3
      • Use a Jimmy to pry off the black backplate.
      Ask FixBot
Krushnam Badami
342 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 72
All Time: 917
