HP Pavilion 15-b109wm RAM Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
69
All Time:
1,252
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show you how to replace your Memory Module in your HP Pavilion 15-b109wm. This process will take about 1 hour, and is very tedious. So take your time, complete each task carefully, and you'll have a successful replacement of your Memory Module.
Tools
    1. HP Pavilion 15-b109wm RAM Replacement, Battery: step 1, image 1 of 1
      • Power off the device and disconnect from any power source.
      Ask FixBot
    2. HP Pavilion 15-b109wm RAM Replacement: step 2, image 1 of 1
      • Turn the device upside down and ensure the back of the device is facing you.
      Ask FixBot
    3. HP Pavilion 15-b109wm RAM Replacement: step 3, image 1 of 3 HP Pavilion 15-b109wm RAM Replacement: step 3, image 2 of 3 HP Pavilion 15-b109wm RAM Replacement: step 3, image 3 of 3
      • Push both buttons towards one another simultaneously. The battery slightly pops out.
      Ask FixBot
    4. HP Pavilion 15-b109wm RAM Replacement: step 4, image 1 of 3 HP Pavilion 15-b109wm RAM Replacement: step 4, image 2 of 3 HP Pavilion 15-b109wm RAM Replacement: step 4, image 3 of 3
      • Pull out the battery from the device's battery slot.
      Ask FixBot
    1. HP Pavilion 15-b109wm RAM Replacement, Keyboard: step 5, image 1 of 2 HP Pavilion 15-b109wm RAM Replacement, Keyboard: step 5, image 2 of 2
      • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
      Ask FixBot
    2. HP Pavilion 15-b109wm RAM Replacement: step 6, image 1 of 1
      • Locate the two screw holes that allow access to removing the keyboard.
      • There is a keyboard sign beside both keyboard access holes.
      Ask FixBot
    3. HP Pavilion 15-b109wm RAM Replacement: step 7, image 1 of 1
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • Turn the device onto its side.
      • Using a heavy duty spudger, gently disengage the keyboard.
      Ask FixBot
    4. HP Pavilion 15-b109wm RAM Replacement: step 8, image 1 of 2 HP Pavilion 15-b109wm RAM Replacement: step 8, image 2 of 2
      • Using a plastic opening tool, release the keyboard clips.
      Ask FixBot
    5. HP Pavilion 15-b109wm RAM Replacement: step 9, image 1 of 1
      • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
      Ask FixBot
    6. HP Pavilion 15-b109wm RAM Replacement: step 10, image 1 of 3 HP Pavilion 15-b109wm RAM Replacement: step 10, image 2 of 3 HP Pavilion 15-b109wm RAM Replacement: step 10, image 3 of 3
      • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
      • To detach the connector, release by lifting the black plastic tab up.
      Ask FixBot
    1. HP Pavilion 15-b109wm RAM Replacement, Fan: step 11, image 1 of 3 HP Pavilion 15-b109wm RAM Replacement, Fan: step 11, image 2 of 3 HP Pavilion 15-b109wm RAM Replacement, Fan: step 11, image 3 of 3
      • Using a JIS #1 screwdriver, remove the five 5mm screws.
      • Detach the power button cable.
      • Detach the touch pad cable.
      Ask FixBot
    2. HP Pavilion 15-b109wm RAM Replacement: step 12, image 1 of 3 HP Pavilion 15-b109wm RAM Replacement: step 12, image 2 of 3 HP Pavilion 15-b109wm RAM Replacement: step 12, image 3 of 3
      • Using a plastic opening tool, pry open the top cover.
      • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
      • Gently, pull to detach the fan cable.
      • Be careful so you do not damage the motherboard.
      Ask FixBot
    3. HP Pavilion 15-b109wm RAM Replacement: step 13, image 1 of 1
      • Carefully remove the fan from its slot.
      Ask FixBot
    1. HP Pavilion 15-b109wm RAM Replacement, RAM: step 14, image 1 of 3 HP Pavilion 15-b109wm RAM Replacement, RAM: step 14, image 2 of 3 HP Pavilion 15-b109wm RAM Replacement, RAM: step 14, image 3 of 3
      • Disconnect the cables to the motherboard.
      Ask FixBot
    2. HP Pavilion 15-b109wm RAM Replacement: step 15, image 1 of 2 HP Pavilion 15-b109wm RAM Replacement: step 15, image 2 of 2
      • Remove the eight 5 mm screws with the JIS #1 screwdriver.
      Ask FixBot
    3. HP Pavilion 15-b109wm RAM Replacement: step 16, image 1 of 2 HP Pavilion 15-b109wm RAM Replacement: step 16, image 2 of 2
      • Remove the hard drive.
      Ask FixBot
    4. HP Pavilion 15-b109wm RAM Replacement: step 17, image 1 of 1
      • Unclip the WLAN cable out of its place to allow the motherboard room to move.
      Ask FixBot
    5. HP Pavilion 15-b109wm RAM Replacement: step 18, image 1 of 1
      • Detach the power connector cable.
      Ask FixBot
    6. HP Pavilion 15-b109wm RAM Replacement: step 19, image 1 of 2 HP Pavilion 15-b109wm RAM Replacement: step 19, image 2 of 2
      • Lift up the motherboard from the bottom side of the device.
      Ask FixBot
    7. HP Pavilion 15-b109wm RAM Replacement: step 20, image 1 of 3 HP Pavilion 15-b109wm RAM Replacement: step 20, image 2 of 3 HP Pavilion 15-b109wm RAM Replacement: step 20, image 3 of 3
      • Using your thumbs, push out on the bracket.
      • When the memory module feels loose, pull up on the module.
      Ask FixBot
Stephen Gacioch
437 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 69
All Time: 1,252
