HP Pavilion 15-ay041wm RAM Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
74
All Time:
1,579
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide provides instructions for replacing the RAM of your HP Pavilion15-ay041wm.
RAM makes your laptop's performance work fast. This can be seen in everyday tasks, such as loading applications or browsing the internet.
This guide may be necessary if your laptop is slow in performance.
Before replacing the RAM, restart the laptop, as that may fix the issue. If it does not, be sure to power down the device and check and disconnect any cables from the computer, beginning with this guide.
Tools
    1. HP Pavilion 15-ay041wm RAM Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-ay041wm RAM Replacement, Battery: step 1, image 2 of 2
      • Place the laptop upside down.
      Ask FixBot
    2. HP Pavilion 15-ay041wm RAM Replacement: step 2, image 1 of 2 HP Pavilion 15-ay041wm RAM Replacement: step 2, image 2 of 2
      • Find the battery lock latch on the top left corner.
      • Slide the latch to the right position.
      Ask FixBot
    3. HP Pavilion 15-ay041wm RAM Replacement: step 3, image 1 of 3 HP Pavilion 15-ay041wm RAM Replacement: step 3, image 2 of 3 HP Pavilion 15-ay041wm RAM Replacement: step 3, image 3 of 3
      • Find the battery release latch on the top right corner.
      • Slide and hold the latch towards the left to cover the battery icon.
      • Carefully slide the battery outwards.
      Ask FixBot
    1. HP Pavilion 15-ay041wm RAM Replacement, Disc Drive: step 4, image 1 of 1
      • Turn the laptop upside down with the base of the laptop facing you.
      • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
      • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
      Ask FixBot
    2. HP Pavilion 15-ay041wm RAM Replacement: step 5, image 1 of 3 HP Pavilion 15-ay041wm RAM Replacement: step 5, image 2 of 3 HP Pavilion 15-ay041wm RAM Replacement: step 5, image 3 of 3
      • Press the eject button.
      • Hold and carefully slide the disc drive out of the laptop.
      Ask FixBot
    1. HP Pavilion 15-ay041wm RAM Replacement, Keyboard: step 6, image 1 of 3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: step 6, image 2 of 3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: step 6, image 3 of 3
      • Using the Jimmy, create a separation between the keyboard and bottom panel.
      • Slide around the body of the panel until the separation is big enough for you to use your fingers.
      • Separate the keyboard and bottom panel.
      Ask FixBot
    1. HP Pavilion 15-ay041wm RAM Replacement, RAM: step 7, image 1 of 3 HP Pavilion 15-ay041wm RAM Replacement, RAM: step 7, image 2 of 3 HP Pavilion 15-ay041wm RAM Replacement, RAM: step 7, image 3 of 3
      • Orient the base of the laptop with the base facing away from you.
      • With you index finger and thumb, position your thumb underneath both latches on either side of the RAM and squeeze outwards.
      • Simultaneously, use your index finger to push the RAM sticks towards you.
      • The RAM stick will release and pop up and out.
      Ask FixBot
    2. HP Pavilion 15-ay041wm RAM Replacement: step 8, image 1 of 2 HP Pavilion 15-ay041wm RAM Replacement: step 8, image 2 of 2
      • Repeat the same process for the top RAM stick.
      • The RAM stick will release and pop up. Pull the RAM stick out to remove it from the laptop.
      Ask FixBot
Carlton Makini
210 Reputation
1 Guide authored
1 Guide Comment
Saludos, necesito saber las conexiones correctas desde la toma del cargador hasta la placa pues perdí la cinta que conecta a la placa y quisiera hacerle una adaptación. Tiene 8 conexiones y por o general son 4 positivos y 4 negativos, pero tengo dudas en este modelo
Yuniel Fonseca - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 74
All Time: 1,579
