HP Pavilion 15-ay041wm Keyboard Replacement
    1. HP Pavilion 15-ay041wm Keyboard Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-ay041wm Keyboard Replacement, Battery: step 1, image 2 of 2
      • Place the laptop upside down.
      Ask FixBot
    2. HP Pavilion 15-ay041wm Keyboard Replacement: step 2, image 1 of 2 HP Pavilion 15-ay041wm Keyboard Replacement: step 2, image 2 of 2
      • Find the battery lock latch on the top left corner.
      • Slide the latch to the right position.
      Ask FixBot
    3. HP Pavilion 15-ay041wm Keyboard Replacement: step 3, image 1 of 3 HP Pavilion 15-ay041wm Keyboard Replacement: step 3, image 2 of 3 HP Pavilion 15-ay041wm Keyboard Replacement: step 3, image 3 of 3
      • Find the battery release latch on the top right corner.
      • Slide and hold the latch towards the left to cover the battery icon.
      • Carefully slide the battery outwards.
      Ask FixBot
    1. HP Pavilion 15-ay041wm Keyboard Replacement, Disc Drive: step 4, image 1 of 1
      • Turn the laptop upside down with the base of the laptop facing you.
      • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
      • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
      Ask FixBot
    2. HP Pavilion 15-ay041wm Keyboard Replacement: step 5, image 1 of 3 HP Pavilion 15-ay041wm Keyboard Replacement: step 5, image 2 of 3 HP Pavilion 15-ay041wm Keyboard Replacement: step 5, image 3 of 3
      • Press the eject button.
      • Hold and carefully slide the disc drive out of the laptop.
      Ask FixBot
    1. HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: step 6, image 1 of 3 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: step 6, image 2 of 3 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: step 6, image 3 of 3
      • Using the Jimmy, create a separation between the keyboard and bottom panel.
      • Slide around the body of the panel until the separation is big enough for you to use your fingers.
      • Separate the keyboard and bottom panel.
      Ask FixBot
Kristen Gismondi
108,508 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
84,755 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 33
All Time: 1,206
