HP Pavilion 15-au123cl RAM Replacement
    1. HP Pavilion 15-au123cl RAM Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is off and unplugged before starting.
      • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
      Ask FixBot
    2. HP Pavilion 15-au123cl RAM Replacement: step 2, image 1 of 2 HP Pavilion 15-au123cl RAM Replacement: step 2, image 2 of 2
      • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
      Ask FixBot
    3. HP Pavilion 15-au123cl RAM Replacement: step 3, image 1 of 2 HP Pavilion 15-au123cl RAM Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, remove the back cover of the laptop.
      • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
      • Be sure not to bend the cover by applying too much force.
      Ask FixBot
    4. HP Pavilion 15-au123cl RAM Replacement: step 4, image 1 of 2 HP Pavilion 15-au123cl RAM Replacement: step 4, image 2 of 2
      • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
      Ask FixBot
    5. HP Pavilion 15-au123cl RAM Replacement: step 5, image 1 of 3 HP Pavilion 15-au123cl RAM Replacement: step 5, image 2 of 3 HP Pavilion 15-au123cl RAM Replacement: step 5, image 3 of 3
      • Carefully disconnect the cable connecting the top of the battery and remove the battery.
      Ask FixBot
    1. HP Pavilion 15-au123cl RAM Replacement, RAM: step 6, image 1 of 2 HP Pavilion 15-au123cl RAM Replacement, RAM: step 6, image 2 of 2
      • The RAM is located at the lower middle region of the motherboard.
      • Push down on the clips on both sides of the RAM stick evenly.
      • The RAM will become loose and move upward when the clips are pushed.
      Ask FixBot
    2. HP Pavilion 15-au123cl RAM Replacement: step 7, image 1 of 1
      • Pull the RAM stick out of the motherboard.
      • The same steps work on both sticks of RAM.
      Ask FixBot
2 other people completed this guide.
Mohammad Gardezi
1,420 Reputation
6 Guides authored
USF Tampa, Team S13-G3, Cagle Fall 2017 Member of USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Members
72 Guides authored
1 Guide Comment
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 103
All Time: 1,968
