HP Pavilion 15-au123cl CMOS Battery Replacement
    1. HP Pavilion 15-au123cl CMOS Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is off and unplugged before starting.
      • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
      Ask FixBot
    2. HP Pavilion 15-au123cl CMOS Battery Replacement: step 2, image 1 of 2 HP Pavilion 15-au123cl CMOS Battery Replacement: step 2, image 2 of 2
      • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
      Ask FixBot
    3. HP Pavilion 15-au123cl CMOS Battery Replacement: step 3, image 1 of 2 HP Pavilion 15-au123cl CMOS Battery Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, remove the back cover of the laptop.
      • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
      • Be sure not to bend the cover by applying too much force.
      Ask FixBot
    4. HP Pavilion 15-au123cl CMOS Battery Replacement: step 4, image 1 of 2 HP Pavilion 15-au123cl CMOS Battery Replacement: step 4, image 2 of 2
      • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
      Ask FixBot
    5. HP Pavilion 15-au123cl CMOS Battery Replacement: step 5, image 1 of 3 HP Pavilion 15-au123cl CMOS Battery Replacement: step 5, image 2 of 3 HP Pavilion 15-au123cl CMOS Battery Replacement: step 5, image 3 of 3
      • Carefully disconnect the cable connecting the top of the battery and remove the battery.
      Ask FixBot
    1. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: step 6, image 1 of 2 HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: step 6, image 2 of 2
      • The CMOS battery is located toward the middle left area of the motherboard.
      • Using the spudger, lift the CMOS battery out of its plastic casing.
      Ask FixBot
    2. HP Pavilion 15-au123cl CMOS Battery Replacement: step 7, image 1 of 1
      • Fully remove the CMOS battery from the motherboard.
      Ask FixBot
2 other people completed this guide.
Mohammad Gardezi
1,420 Reputation
6 Guides authored
USF Tampa, Team S13-G3, Cagle Fall 2017 Member of USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 34
Past 30 Days: 154
All Time: 29,024
