HP Pavilion 15-ab243cl CMOS Battery Replacement
    1. HP Pavilion 15-ab243cl CMOS Battery Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-ab243cl CMOS Battery Replacement, Battery: step 1, image 2 of 2
      • Slide the battery lock tab toward the center of the battery to the unlock position.
      Ask FixBot
    2. HP Pavilion 15-ab243cl CMOS Battery Replacement: step 2, image 1 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 2, image 2 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 2, image 3 of 3
      • Slide the battery release switch to the right until the battery pops out.
      Ask FixBot
    3. HP Pavilion 15-ab243cl CMOS Battery Replacement: step 3, image 1 of 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 3, image 2 of 2
      • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
      Ask FixBot
    1. HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: step 4, image 1 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: step 4, image 2 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: step 4, image 3 of 3
      • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
      Ask FixBot
    2. HP Pavilion 15-ab243cl CMOS Battery Replacement: step 5, image 1 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 5, image 2 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 5, image 3 of 3
      • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
      Ask FixBot
    3. HP Pavilion 15-ab243cl CMOS Battery Replacement: step 6, image 1 of 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 6, image 2 of 2
      • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
      • These can strip easily, so take your time removing.
      Ask FixBot
    4. HP Pavilion 15-ab243cl CMOS Battery Replacement: step 7, image 1 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 7, image 2 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
      Ask FixBot
    5. HP Pavilion 15-ab243cl CMOS Battery Replacement: step 8, image 1 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 8, image 2 of 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 8, image 3 of 3
      • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
      • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
      Ask FixBot
    1. HP Pavilion 15-ab243cl CMOS Battery Replacement, CMOS Battery: step 9, image 1 of 2 HP Pavilion 15-ab243cl CMOS Battery Replacement, CMOS Battery: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use long nose tweezers to reach under battery and lift up.
      Ask FixBot
    2. HP Pavilion 15-ab243cl CMOS Battery Replacement: step 10, image 1 of 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: step 10, image 2 of 2
      • Lift up until battery pops out, remove battery
      Ask FixBot
Alexander Bicigo
942 Reputation
6 Guides authored
USF Tampa, Team S6-G3, Eyestone Spring 2018 Member of USF Tampa, Team S6-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S6G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 71
All Time: 2,271
