HP Pavilion 15-ab165us RAM Replacement
    1. HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: step 1, image 1 of 2 HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: step 1, image 2 of 2
      • Flip the computer over so that the bottom cover is facing you.
      • Slide the two locks to the "unlock" position and remove the battery.
      Ask FixBot
    2. HP Pavilion 15-ab165us RAM Replacement: step 2, image 1 of 3 HP Pavilion 15-ab165us RAM Replacement: step 2, image 2 of 3 HP Pavilion 15-ab165us RAM Replacement: step 2, image 3 of 3
      • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
      • Use a plastic opening tool to remove the plastic feet.
      Ask FixBot
    3. HP Pavilion 15-ab165us RAM Replacement: step 3, image 1 of 3 HP Pavilion 15-ab165us RAM Replacement: step 3, image 2 of 3 HP Pavilion 15-ab165us RAM Replacement: step 3, image 3 of 3
      • Remove the two plastic tabs with a metal spudger.
      Ask FixBot
    4. HP Pavilion 15-ab165us RAM Replacement: step 4, image 1 of 1
      • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
      Ask FixBot
    5. HP Pavilion 15-ab165us RAM Replacement: step 5, image 1 of 1
      • Pull the Optical Drive out.
      Ask FixBot
    6. HP Pavilion 15-ab165us RAM Replacement: step 6, image 1 of 1
      • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
      Ask FixBot
    7. HP Pavilion 15-ab165us RAM Replacement: step 7, image 1 of 2 HP Pavilion 15-ab165us RAM Replacement: step 7, image 2 of 2
      • Flip the computer back over.
      • Use a plastic opening tool to release the clips holding the keyboard section in place.
      Ask FixBot
    8. HP Pavilion 15-ab165us RAM Replacement: step 8, image 1 of 1
      • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
      • The hard drive is NOT screwed into place on the underside of the keyboard section.
      Ask FixBot
    1. HP Pavilion 15-ab165us RAM Replacement, RAM: step 9, image 1 of 1
      • Locate RAM.
      Ask FixBot
    2. HP Pavilion 15-ab165us RAM Replacement: step 10, image 1 of 1
      • Pull the tension arms away from both sides the RAM.
      Ask FixBot
    3. HP Pavilion 15-ab165us RAM Replacement: step 11, image 1 of 1
      • Pull RAM away from the RAM slot.
      Ask FixBot
    4. HP Pavilion 15-ab165us RAM Replacement: step 12, image 1 of 1
      • Repeat this process for the next stick of RAM.
      Ask FixBot
3 other people completed this guide.
Myai Nguyen
206 Reputation
1 Guide authored
UW Tacoma, Team S1-G2, Rose Fall 2017 Member of UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 96
All Time: 2,796
