HP Pavilion 14-v062us Keyboard Replacement
    1. HP Pavilion 14-v062us Keyboard Replacement, Battery: step 1, image 1 of 2 HP Pavilion 14-v062us Keyboard Replacement, Battery: step 1, image 2 of 2
      • Power laptop off and make sure it is not plugged into charger
      • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
      Ask FixBot
    2. HP Pavilion 14-v062us Keyboard Replacement: step 2, image 1 of 2 HP Pavilion 14-v062us Keyboard Replacement: step 2, image 2 of 2
      • Lift the battery upwards and out from the laptop
      Ask FixBot
    1. HP Pavilion 14-v062us Keyboard Replacement, Keyboard: step 3, image 1 of 3 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: step 3, image 2 of 3 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Remove rectangular rubber tops with a spudger
      • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
      • Remove plastic edge covering with the blue plastic opening tool.
      • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
      Ask FixBot
    2. HP Pavilion 14-v062us Keyboard Replacement: step 4, image 1 of 2 HP Pavilion 14-v062us Keyboard Replacement: step 4, image 2 of 2
      • Use Phillips screwdriver #1
      • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
      • Remove the three 7.14 mm PH#1 screws.
      • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
      Ask FixBot
    3. HP Pavilion 14-v062us Keyboard Replacement: step 5, image 1 of 2 HP Pavilion 14-v062us Keyboard Replacement: step 5, image 2 of 2
      • Remove disc tray
      • Locate screw within computer that is inside of where the disc tray was
      • Using a Phillips #1 screwdriver, unscrew the screw
      • Set laptop down and open laptop so the keyboard is facing you
      Ask FixBot
    4. HP Pavilion 14-v062us Keyboard Replacement: step 6, image 1 of 3 HP Pavilion 14-v062us Keyboard Replacement: step 6, image 2 of 3 HP Pavilion 14-v062us Keyboard Replacement: step 6, image 3 of 3
      • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
      • Pry until you are able to lift entire face and keyboard
      • Only cables should be connecting it underneath
      Ask FixBot
    5. HP Pavilion 14-v062us Keyboard Replacement: step 7, image 1 of 3 HP Pavilion 14-v062us Keyboard Replacement: step 7, image 2 of 3 HP Pavilion 14-v062us Keyboard Replacement: step 7, image 3 of 3
      • Disconnect/ unplug cables using plastic opening tool.
      • Separate the keyboard panel from the laptop with your hands.
      • Turn around the laptop and lay it flat.
      Ask FixBot
    6. HP Pavilion 14-v062us Keyboard Replacement: step 8, image 1 of 2 HP Pavilion 14-v062us Keyboard Replacement: step 8, image 2 of 2
      • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
      • Only use a metal spudger as a last resort
      Ask FixBot
    7. HP Pavilion 14-v062us Keyboard Replacement: step 9, image 1 of 3 HP Pavilion 14-v062us Keyboard Replacement: step 9, image 2 of 3 HP Pavilion 14-v062us Keyboard Replacement: step 9, image 3 of 3
      • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Thank you so much, this guide is very helpful.
Rodolfo Trujillo - Reply Share
Thank you for the guide. It was very helpful!
dmitryp80 - Reply Share
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 105
All Time: 2,556
