HP Pavilion 14-n018us RAM Replacement
    1. HP Pavilion 14-n018us RAM Replacement, Battery: step 1, image 1 of 2 HP Pavilion 14-n018us RAM Replacement, Battery: step 1, image 2 of 2
      • Prior to removing the base plate, the battery must be removed.
      • Press the two tabs on the back of the laptop inward to release the battery.
      • Pull the battery straight out slowly and firmly.
      Ask FixBot
    1. HP Pavilion 14-n018us RAM Replacement, Memory Module: step 2, image 1 of 2 HP Pavilion 14-n018us RAM Replacement, Memory Module: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, unscrew the two 6.98 mm captive screws on the black cover on the bottom of the laptop.
      • Remove the cover.
      Ask FixBot
    2. HP Pavilion 14-n018us RAM Replacement: step 3, image 1 of 3 HP Pavilion 14-n018us RAM Replacement: step 3, image 2 of 3 HP Pavilion 14-n018us RAM Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Push outwards on the two retaining clips on either side of each RAM chip to release the chips.
      • Use a pair of ESD-safe tweezers to gently slide the two memory modules out from the assembly.
      • If you don't have a suitable pair of tweezers, it's okay to use your fingers to remove the RAM chips. Just be sure to handle the chips by their edges, as skin contact on the faces of the chips can damage them.
      Ask FixBot
Michael Hollister
253 Reputation
3 Guides authored
Casper College, Team 1-1, Lareau Fall 2021 Member of Casper College, Team 1-1, Lareau Fall 2021
CASC-LAREAU-F21S1G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 62
All Time: 471
