HP Pavilion 14-n018us Display Assembly Replacement
    1. HP Pavilion 14-n018us Display Assembly Replacement, Battery: step 1, image 1 of 2 HP Pavilion 14-n018us Display Assembly Replacement, Battery: step 1, image 2 of 2
      • Prior to removing the base plate, the battery must be removed.
      • Press the two tabs on the back of the laptop inward to release the battery.
      • Pull the battery straight out slowly and firmly.
      Ask FixBot
    1. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: step 2, image 1 of 3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: step 2, image 2 of 3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: step 2, image 3 of 3
      • Insert a plastic spudger into the groove around the laptop screen and gently loosen the plastic bezel away from the display.
      • Use the plastic spudger and loosen the display away from the back of the screen.
      • Continue to use the spudger to detach the small plastic detents holding the screen in place.
      • Disconnect the display cable and remove the screen.
      Ask FixBot
    2. HP Pavilion 14-n018us Display Assembly Replacement: step 3, image 1 of 1
      • The screen can now be reassembled!
      Ask FixBot
Michael Hollister
253 Reputation
3 Guides authored
Casper College, Team 1-1, Lareau Fall 2021 Member of Casper College, Team 1-1, Lareau Fall 2021
CASC-LAREAU-F21S1G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 439
