HP Pavilion 14-cf0014dx SSD Replacement
    1. HP Pavilion 14-cf0014dx SSD Replacement, Back Panel: step 1, image 1 of 1
      • Flip the device over so that the backside is facing you.
      • Remove the rubber feet to expose six screws.
      • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
      Ask FixBot
    2. HP Pavilion 14-cf0014dx SSD Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool and run it along the edges of the laptop.
      • Remove the back panel from the device.
      Ask FixBot
    1. HP Pavilion 14-cf0014dx SSD Replacement, Battery: step 3, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
      Ask FixBot
    2. HP Pavilion 14-cf0014dx SSD Replacement: step 4, image 1 of 1
      • Lift the battery up and out and remove it from the device.
      Ask FixBot
    1. HP Pavilion 14-cf0014dx SSD Replacement, SSD: step 5, image 1 of 2 HP Pavilion 14-cf0014dx SSD Replacement, SSD: step 5, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the single screw securing the SSD to the motherboard.
      Ask FixBot
    2. HP Pavilion 14-cf0014dx SSD Replacement: step 6, image 1 of 2 HP Pavilion 14-cf0014dx SSD Replacement: step 6, image 2 of 2
      • Carefully pull the SSD out of the slot.
      Ask FixBot
Sam Cole
813 Reputation
7 Guides authored
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Members
84 Guides authored
1 Guide Comment
Hola!, ¿cómo es el cable para el SSD (Hard drive cable L23187-001), así como su case? (Hard drive cover L23219-001) La imagen que me aparece en la red del cable es muy largo. Gracias.
Ernesto P Mitre M - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 1,163
